Hello Hello
Im looking at hiring a 1.5ton (or equiv) Van or 3ton truck to move a few furniture items this Sat. I'd prefer a van though as its generally cheeper...
I've tried Europecar, Thirfty, and Budget and got their prices.
My question is, does anyone know of any other places maybe that are not franchised which would be able to hire out for a cheap price???
Preferably Northern subs, but will be picking items up from Noble Park....
EDIT:
Orrrr, if anyone has one that is willing to lend it out to me for a day i will be more than happy to pay for it*.
Dislaimer: *Sexual favours excluded loll
there is a lil van hire place on north rd in between clayton rd and huntingdale rd bridge in huntingdale. its called lloyds rent a van, they have ford vans there for hire. i think wen we hired one wen i moved it was 60 bucks for the day.
1356 North Rd Oakleigh 3166
(03) 9562 8122
0413 543 543
speak to mini movers
they are pretty cheap and might just be easier to use them - find out a cost
If he thinks budget etc are a little pricy then mini movers are out of the question. I work for a removalist company and on a Saturday we charge $119 an hour with time starting when we leave our depot and finishing when we return.
We are cheaper than mini movers.
Budget and Thrifty were around the $140-$160 mark (cant remember exactly) just for the van on a Saturday which is pretty expensive imo. I also tried AVIS who weren't any good either...
I ended up booking Europecar; got a 3ton truck for $87 and an extra $20 for insurance. Gonna be using it on Sunday to clear out the furniture of my partner's father who passed away on Sunday fighting lung cancer.
And just for a lil quick tip for anyone reading this in the future, even though you pay $20 for insurance you still have to pay the excess ($550 in this case) in the event of an accident and that's regardless of whether ur at fault or not!!! :)
Thanks guys for ur replies....
$87.00 is a good price.
But read the fine print as it does not cover damage to the Pantec (the box on the back).
Beware of bridges and the most common is wiping out trees when pulling over along with taking out power/phone lines backing up a driveway. Look up!!
dam thats expensive for a van, im glad i work for a transport company, i can use anything from a 1ton hi ace to a semi for the price of fuel, the down side is who do you think my mates call when ever they need some thing moved :thumbsup: i even had a mate want me to get an 8ton rigid, help him load it chock full of furntiture and then take it to ballarat and unload it, i got sick very quickly.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
