Hello i would like to know the HP diference between a 63 and 82 ar gt35r, with stock cams, i was told by a couple of well known engine builders, that the diference on a stock camed engine particularly wit the gt35r that the diference up top would be around 15 whp. has any 1 had any direct experiance with something like this, 1 of my engine builder buddies dyno'd 540 rwhp on a clients rb25, greddy intake manifold q45 throttle body, with a ported head, at 24 psi with a gt35 ar .63 ar housing and an AEM ecu
Regan
https://www.sau.com.au/forums/topic/222265-gt35r-question/
you shouldnt be worrying about power with exhaust housing to much. thats for the actual turbo size itsself mianly.
exhaust housings should be used to determine how agressive you want your car.
someone posted on here before saying he didnt hit full boost until 5000rpm using a 1.06. which is just a lil to late.
if your still running the 2.5 engine with no cams. stick with .63 or a .86
but to answer your question, i have no idea sorry.
Edited by R34NRG
https://www.sau.com.au/forums/topic/222265-gt35r-question/#findComment-3916487
Regan
Im running the .63 rear version, although I have poncams but the rest is the same (Q45 etc) ... havent had the final tune yet but 306rwkw on 16 psi atm (quick tune after engine was run in)... 25psi roughly being the end target... My tuner reckons the rear will max out around the 340ish mark.. Il know by the weekend :blink:
He was impressed at the response though, and said it wouldn't be worth the extra kw at the top end to sacrifice the response I currently have. Although I do have the .82 rear on standby... :P
https://www.sau.com.au/forums/topic/222265-gt35r-question/#findComment-3917638
400rwkw (540rwhp) from a .63 housing and 24psi seems just a little unbelieveable to me.
The .63 limits the GT35 to around 600hp, and it would be so severely choked.
hrm... The .82 (depending on comp wheel) is rated to 700hp i thought? And the 1.06 was the same, just for larger capacity motors so they arent too restricted.
If you have a .63, it'd be getting a turbo from the smaller family, GT3071, GT3076 etc.
.82 for the GT35 or 1.06.
Thats just my choice having had a 600hp GT30/.82, show was on approx 4200rpm (stock RB25 head) really linear but a 550hp/.63 probably better :)
https://www.sau.com.au/forums/topic/222265-gt35r-question/#findComment-3917950
Thats just my choice having had a 600hp GT30/.82, show was on approx 4200rpm (stock RB25 head) really linear but a 550hp/.63 probably better ;)
hahaha thats the biggest load of crap i have heard all year 400rwkw from a .63 housing..lol in your dreams!
the max youll get 340-360 and thats running more than 24psi.. on 1.5bar i was getting 330-340rwkw and it was running a little rich...
https://www.sau.com.au/forums/topic/222265-gt35r-question/#findComment-3919234
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
