Make: R31 Skyline
Model: 3.0L Excutive
Transmission: RB25DET AUTO
Colour: White over Black
Currently registered? Yes
Price: $3000 ONO
Contact: PM Me to inspect or view pictures
Comments / Modifications:
-New Injectors
-Turbo Conversion (T04E, High Mount Manifold, Front Mount, etc.)
-3 Inch Turbo Back Exhaust
-XF Throttle Body
-RB25T Auto Box
-Boost Controller
-Oil Catch Can
-Blue Plated and Legal
-Freshly Buffed Paint
Comes With:
Complete Spare Rb30 with gasket set
This is one fast R31 and it doesn't attract attention.
The bottom end of the motor is a little tired(rings are gone i believe), hence why I am supplying the other motor with it.
Had it Checked out a Goodyear for a major service...
A few things they listed that need replacing:
-Fan Belts
-Bump Stops
-Front Struts
-Wheel Alignment
Any questions feel free to ask...
Cheers.
Brad
https://www.sau.com.au/forums/topic/222268-turbo-r31/
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
