  • Replies 260
sounds like you are!!!
Good luck after the shit-storm last year!
Anyways I am out for this one... get back from Vanuatu the day before it. Might pop in for a look tho over the course of the weekend.
*I guess its a case of log your interest in this thread..........
https://www.sau.com.au/forums/topic/222285-autosalon-08/#findComment-3916818
Why does it have such a bad rep???
I mean yes its not everyones cup of tea, the flashiness. (made a word up!) But there are some pretty impressive cars there... Why slag it?
Also why not then put in a few cars dedicated to power and show what real cars have got...
https://www.sau.com.au/forums/topic/222285-autosalon-08/#findComment-3916935
Must say, not surprised at Darren being 2nd post (and the content) :D
I don't have a skyline or show-worthy car. Hopefully those that represented us last year can do good again (even amongst the shit-flinging)
Do you know how hard it was to hold off for that 15 min :blush: Had to be said............
Oh i forgot in my first post, Dont forget to polish up the bling peoples, this includes chrome 20x7 rims, rice lights, love heart shaped exhaust tips, chrome valve caps, etc!!
Edited by Deluxe
https://www.sau.com.au/forums/topic/222285-autosalon-08/#findComment-3917003
you have to admit, amongst the boring show cars with revolting body kits :D there are some pretty impressive cars on display.
power/engine wise.
exactly so why dont we be different and try for a mix... few nice horse power and some show.... or try and get a R31 GTS 2 door, 32 GTR, 33 GTR and 34 GTR with nice horse power in a line also?
https://www.sau.com.au/forums/topic/222285-autosalon-08/#findComment-3917102
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
