  • Replies 260
I think Adam and Craig should head it up
you dont start a tread about a topic saying yeah this yeah that who wants to organise it for me
grab each others phone numbers get together and discuss what you like its easy
haha thanks... id help but im not reali and organiser! lol
cara missr34 who seems to not be online these days is keen on going, and yeah i wanna hear how much were talking $$ i may bring out the night kids mobile im sure the intial d kids will like it there.
Cara is part of another display
Flick, just how much extra cost roughly was needed all up?
i think all the entrents chiped in like 40 or 50 bux, i cant remember but we had a friend set up the lighting and people that others knew as promo girls etc. but im sure the orginisers might have put in more and they really kept other informed about whats going on. we had a meeting and PK brough down a laptop with a layout of what they had planned.
there was so much going on but the orginiser took most of the workload :) thats why i said the people who run this one have some big shoes to fill.
Haha be optamistic!!!!
What would look cool is a Pimped R31 then a standered high powered GTS 2 door, the a Pimped GTST R32 then a high powered 32 GTR, etc etc and have an 8 car display.. mix of power and looks
its what we had last year, looks and power. but to win anything it needs to all be set up right.
goodluck!
^what kye said, all entrants put about $50 in each, but i chipped in a bit more and i know PK spent aloooot more again than me.
As i said, happy to help organize. Ill start making a list of who is keen to enter. PM me if you are keen so i can add you to the list. but please, think hard about it.. dont want to waste my time and effort if people start changing their mind or saying im a maybe etc. Its only a few months away and it will take that much time to get it sorted, believe me.
So pm me if you are interested and we will go from there.
yeas sorry guys wont be part of this years SAU display.......ive been organising my own display for a little while.
but good luck with it all.....try and get it organised asap tho early bird entry fee closes on july 11.
see you there tho :happy:
OK, I'll step up.
I am happy to organize the event if needed, but would greatly appreciate help.
Could you PM me if you have a car and will enter (assuming we get 4 or more cars).
We had a great display last year (I missed out due to a car crash) so how many of last years group have cars suitable to show (either power or bling)
guy, you need 6 cars minimun in a display to be judged as a group so that would be the minimum number to aim for. Hopefully you get enough, be good to see another decent display after the effort people put in last year.
Im pretty sure im gunna enter the LIMO just for shits and giggles this year. Unless a Drift event clashes with this years Autosalon.
I just want to put it on the Dyno and see peoples reactions. HAHAHAHAHAHAH
A big black limo thingy pushing 300rwkw's hahahaha
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
