  • Replies 260
some useful information i received via email today
Just a couple of points I want everyone to be aware of this year relating to entries being submitted:
1. Photo's are required. Please send via email and include your details.
2. All entrants including clubs MUST have flooring to be eligible for judging.
3. All entrants must be registered and in the show by 10:00pm when lockdown will occur and disqualifications may apply after this time.
4. No private competitor regardless of being in Pro or Expert Class is allowed to actively promote a business by way of printed material, regardless of what sponsorship deals they have. In order to promote a business, either the competitor on behalf of the business or the business itself, will have to reach a trade agreement with Auto Salon.
Just quietly Craig, it doesnt just double, it goes to about $250 ish per person instead of $80. That info is from the Autosalon application form
$250 :D f**k! For $80, I might be keen to enter the Stagea ... but not $250. What are the other 'hidden' extras?
So those with (for example) a BoostWorx sticker on the back window are not allowed? Thats a bit harsh.
sulking id say.
he said '' you can find someone else for A.S, cos im out'' during that whole ''ban'' thingy
so i did. and guess what, IT LOOKS 10 X BETTER!
Figures :)
Edited by RubyRS4
Figures :D
it says printed material. so you could have said stickers on your car, but no business flyers
Edited by Matty 31
im sure they would be more understanding with ''tuned by'' stickers. well i hope so any way!
ruby, would be good to have the stag in there!
the only hidden costs will be flooring etc when devided by 7 of us = f**k all.
if it was specifically for flyers then it should have said that, however it is saying printed material, which can mean stickers, business cards, flyers, banners etc.
as it does not specify exactly what printed material is then we can only assume it includes any sort of printed material as mentioned above.
Hmm, reckon I could have the $80 before the 25th deadline.
Biggest problem is I got a trip interstate coming up and I'm swapping my Days kit for a Dolphin kit. If it doesn't fit just right (FMIC and all) and doesn't get colour matched quickly, the Stagea won't be presentable for the show.
Take me in as a very serious "maybe". So where do I get the application form from? I'm sure its been said, but I'm feeling lazy tonight. :P
DUE TO LACK OF COMMITTMENT, INTEREST AND PEOPLE PULLING OUT,
THIS YEARS SAU DISPLAY AT AUTOSALON
HAS BEEN CANCELLED.
IT HAS BEEN LEFT TO LATE
WITH THE AMOUNT OF WORK THAT STILL HAS TO BE DONE
TO MAKE A DECENT DISPLAY.
THIS WAS A COMBINED DECISION BY THE ORGANISERS.
SORRY TO ALL THAT WHERE LOOKING FORWORD TO IT.
THANKS.
CRAIG, GUY AND FLICK.
craig i know my car aint too hot but if u need ppl to do the display ill be more than happy to put my car in! im sure scott will too! and even adam!
we need to have the sau display!!
ill have my gtr bar on and painted! but my overall paint isnt the best!
scott and adams cars r in great nic so im mor ethan happy to go in to have the display!!
its not just the cars dropping out though...we still need flooring, lighting etc.
i have never done anything like this before, so im not sure how to organise anything
and flick has been really busy herself..
its pretty dissappointing i know.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
