Ok i just bought my new car and the previous owner must have had a field day with the electrics...
Problem List.
I have a Master Switch to give power to car and a button to start the car...
My dash lights, parkers and taillights turn on via fog light switch on dash (turns boost gauge back light off)
Normal switch on dash turn head lights on...
Head unit is a JVC-DVD Head unit (KD-DV4306) It has 2 RCA outs and im trying to run a
4 channel amp, do i need to buy a new head unit and what plugs do i plug from the HU-AMP
I get plenty of interference from car noise (revs and shit... you know what i mean) the RCA cables are
running down the centre of the car and the power cable is running down the drivers side of the car they
only meet under the back seats. Do i need to run these as far away from each other and how do i get rid
of this interference? These are all new cables which i have ran myself and the kit prob set me back $60 if
that helps at all... Is it the amp itself? If i buy a 5 channel kicker amp would i need to grab a new Headunit?
Hey thanks for any help im pretty puzzled!
https://www.sau.com.au/forums/topic/222298-few-car-audio-questions/
Problem List.
To cancel out the noise buy some ground loop isolators. although the fact that you only spent $60 on the wiring kit suggests poor quality cables so i would be looking at getting some good quality RCA's too. As for the amp if you plan on running a sub i recommend getting a headunit with sub out. (should be 3 pairs of RCA's in the back of headunit. 1pair front 1pair rear 1pair sub. if you only have 1pair it can all be run but wont sound as good and all balancing will have to be done on amp only balance on headunit would be left right.
you puzzled me with all that stuff.. what are you chasing with all that lol..
your rca's can't run near ANY electrics.. IF by any chance you do then cross at 90deg to each other.. but yes better rcas and isolators will reduce noise..
move your rcas down the passanger side, everything else i could make sense of has been handled by nissanskyrice
Edited by .:: GimpS-R34 ::.
For others, also check the size of the grounding cable on the Battery, I did a complete install in my R32 GTR, and the ground on that is slightly smaller than an 8 guage wire, which is completely inadequite qwith a 4guage power feed for the Amps alone, let along the rest of the car's electronics.
My sugestion would be on cars suffering from engine noise, get a custom earth kit from somewhere like FHRX Studios, and make sure all your grounding points are adequite.
B.
just a question how do u find the headunit has it lost memory at all when u turn ur car on. i had 1 of those dvd players and it was always loosing memory even with the constant power wire straight 2 the battery.
If this happens, you might have the wiring around the wrong way:
I.E Yellow is meant to be connected to Constant 12v+
Red is meant to be connected to 12v+ when Acc is turned on
Black is meant to be Constant Ground/Earth.
Some people have accidently switched the yellow and the red, and this doesn't effect the player when you test the on/off function, because the it's being fed 12 volts to the Acc to turn on, but doesn't have a constant 12v so it's off, but then when you turn the key to Acc, it feeds the constant 12v and thus power's up as normal.
Problem is, the constant 12v is what feeds power to the headunit to hold it's memory, without this, you loose memory every time you shut the car off.
B.
B.
yeah but it never done it all the time and i had it wired up correctly i had the constant 12+ running straight 2 the battery 2 bypass the imobilser and everything. it would sumtimes do it every time i turned the car on but most of the time it would hapen like the 6th time the car would b turned on. also workin at supercheap ive also had a few others come back with the same problem and the were wired in by profesionals.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
