Have you tried having the knock sensors on a switch, so they can be off when its warming up, and then turn them on once its warm. I believe it wouldn't change your power output, as its your other tricks that are giving oyu the power. As SK said this is merely fooling the ecu into believing there is no knock, so if there is no knock, in theory there should be the same outcome.
Yep thought about doin that but the switch bounce 'may' be detected as knock by the ECU....
And yep..that is all i am doing..fooling the ECU...
pitty its not a subaru. in them if there is a knock sensor fault it pulls back timing 10 degrees while under any load..... lol
Nice one...The first post already says that any knock sensor fault (open/closed circuit) activates ignition retard...
I would say every single ECU with knock sensor capability would do this...
Interesting.............I have a a question though. If excessive airflow on its own doesn't activate R&R why do I see rich A/F ratios and retarded timing on the dyno even when there is zero knock? The Stagea suffers from this on cold days. I run 100 ron fuel (Shell V Power Racing) with the SITC retarding the ignition and so there is no knock that I can detect, but the A/F ratios drop from high 11's down to low 9's and the ignition retards 10 to 15 degrees. Maybe the ignition cut can explain the richer A/F ratios due to the resulting unburnt fuel, but it doesn't account for the retarded ignition. The R&R isn't as severe as when there is knock, but it's still there.
Cheers
Gary
To be honest with my car on the Dyno we didn't see excessively low AFRs but I have heard of it happening...not sure about the ignition advance though...I have the Nissan consult datafiles so I will check...
IMO there is another function in the ecu which detects excessive AFM voltage rise rate, and also exhibits similar traits to R&R, which is what results in the sawtooth power graph you see when you turn the boost up on a stock ecu.
I am running a GT30R which obviously is laggier than stock turbo...so the afm voltage rise rate would be lower at say 2000-3000rpm than with a stock turbo...Maybe the ECU monitors afm v rise rate but only in the low rpm ranges...
If you just disconnect the knock sensors the ECU gives error code 55. When ever this happens the ECU reverts instantly to R&R anyway...Also if you ground the Knock sensor signal wire it also goes to error code 55 which again reverts to R&R mode...(maybe a few people reconnecting their knock sensors about now)...
you sure its 55? 55 is the error code for 'there is no error'. 34 is knock sensor afaik.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
