hey guys,
i'm getting ready for AutoSalon (PERTH - 26th of July) and i'm running out of time, have ordered a kit from a sponsor and got told i should go to another sponsor and then also got told i should use Carmate...
OKAY now i would love EVERYBODY'S opinion...
what is the fitting and quality like of Carmate's products, in particular, those of the R34 (ordering URAS/BN Sports kit)...
i don't want anybody to say good or bad things about other workshops/manufacturers/or the like
i just want opinions on the quality of [CARMATE]'s products...
those with experiences please share as i'm looking to purchase ASAP
cheers,
Andrew :)
https://www.sau.com.au/forums/topic/222347-carmate/
not an R34
but all the same i bought a VT Monaro (Fiberglass copy) from CarMate.. some modification of course for rubber stoppers/levelers.. but fitment was very close (the top of the bonnet was up couple of mm.. was only top corners, not noticable unless bonnet was looked over..
not exactly what your after but every bit helps.. i would recommend them on that basis but havent bought any other body parts from them since.. i bought all my fiberglass for the skyline from DMD so get some other recommendations too (on CarMate i mean)
Quality seems ok.. got no complaints about it
Edited by .:: GimpS-R34 ::.
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3918187
LOL at them for wanting my car for three days to fit and paint rear pods. ;)
Oh, and them fitting my A/F gauge in a chrome cup when i specifically said i wanted it mounted in the autometer piller holder.
On the brighter side, they can make any sticker you want if you supply the program.
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3918959
thanks for the input dude but i don't want to know about their services, i wish i was in NSW to talk to them but i just need to know what their products are like...
no use waiting a week or so patiently to find out the stuff doesn't fit and have to muck around with the parts... wastes my time getting ready for the show...
getting really agitated, never thought buying body parts could be so much to think about ;)
on the topic though, anybody know where i can buy Ganador's for R34?
mate had R32 pair for sale, no chance they would fit lol
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3918969
I have a carmate fg bonnet, it fitted very well no modification required, just paint fit some bonnet locks (aerocatch) and replace stock bonnet, easy...
The only complaint would be the mesh they supplied on the vents was crap, so I left it off, the mount points for the mesh are ok'ish but I wish they wern't there at all..... I will also be getting made some fg panels mounted somehow to plug the vents for wet days. I don't like the mess the water makes, especially if your into keeping your engine bay clean and polished.
otherwise decent fibreglass job.. good fit. can't comment on delivery as I bought it new off someone else.
oh photos
Edited by 75coupe
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3918985
NNNOOOOO!!!!! dont go through carmate as they have a bad rep wen they do send out kits BUT....Jack at X-racing is very good he supplies some of carmates and jetspeeds kits.....and jack makes all the kits himself so he doesn't import or buy from no one their all made by him...he did mine.... www.xracing.com.au
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3920260
thanks mate, great comments...
keep them coming fellas!
Hi
The owner's name is Steve.
He's quite straightforward and honest - I recommend that you talk to him in case you need to make a comeback
I bought a V-Spec front splitter off them and had it fitted there - a perfect fit - no adjustments necessary except to replace bolts with speedclips later
I then had a fitting of 'JU' side skirts and the cut and fit was terrible - so of course being a 'John West' fan I rejected them
Now getting Nismo side skirts and rear pods from www.jsai.com.au The guy's name is Josh - honest and friendly. He has lots of Nismo kits
Josh makes all the kits himself - 3 week waiting list at present unless he has a stored stock item in his mezzanine storage
Tell me if want a NACA Duct (as in a V Spec II) and there's another source for that
Cheers,
Terry
https://www.sau.com.au/forums/topic/222347-carmate/#findComment-3922555
    • The Neat gears use an alternative profile, no? Something different to what normal OEM stuff is. Is the noise at all traceable to that? Reason I ask is that my CW&P are effectively past their use by bate and Neat is the obvious option.
    • Just picked up my first skyline. R34 4 door with an rb25det and manual swap. I’m in the US. It has a bunch of issues but the problem I’m chasing now is the indicator, hazards, and horn do not work. I took out the indicator relay and fuses and tested separately and they seem to be working fine. When I activate the turn signal stalk or the hazard button nothing happens, no clicking, and no dash lights. Same with the horn. What should I test next? The headlights, taillights, and brake lights work fine so I think the stalk is good.
    • RD25 neo... sorry bad joke ill see myself out
    • Sorry just googled Toyota WiLL Vi and wish that I didn't, day ruined, fark etc.
    • So mines not in yet ... which should tell you something ...   I got a set of neat gears as well, took a year to get those. Then the setup was a real tricky one, with all the changes. It seems the shims for the front diffs are in short supply and had to wait two round of custom ones. This was all done by a professional diff builder , not me/diy.   So here we are about to go into 2025 and I do finally have a built front sump / diff / gears.  Just need the mojo to pull out the engine ...   Oh as an aside on the neat gears, they have some whine, mostly on decel. Taken a bit of setup again to get that down to a street car level.
