Hey all,
About a month ago i purchased a 32 gtr but it wasn't until recently i noticed that the front left air duct is blocked off with what feels like a piece of rubber. Is this normal on a stock gtr? The front bar has been resprayed and i'm starting to think that its been left on afterwards. Would this having any effect on the intake?
Thanks
https://www.sau.com.au/forums/topic/222360-does-this-look-right/
Have you checked to see what's behind the cover? If there's an oil cooler there it's got the cover there to keep oil temps up during winter, and taken off during summer/track days.
During a respray the bar will be removed, so it wouldn't need covers to be placed on it.
I'd remove it, but as long as it's not blocking airflow to radiator/intercooler it won't be a drama.
Got my stock gtr r32 and It also came with the rubber flap. It's factory fitment
If you have a look under ther wheel well plastic lyner you will also have a box resinator.
I removed all those and some more plastic intake crap
Got to be at least an extra 100kw worth of more power now :D
Hey all,
Thanks
LOL that looks like masking tape thats been left on after the respray...
it's factory. you can remove it if you want but just removing it wont do anythnig except cost you some aero.
however your car has definitely been resprayed (and not too well by the look of it). the blanking plate from the factory was just black on call cars. damn, I just noticed they painted the factory lip too. what a shame ;)
well lots of GTRs have had them removed over the years. people remove them, and remove the resonator box behind it too. and the duct can be useful if you put an oil cooler in there or use some pipe to duct cool air up to your airbox/pods. but unless you put either of those in there you may as well just leave the blanking plate in.
Behind the wiper bottle on 32R's is a bung that when removed allows air to travel from the left duct...ARC make a vented plate that fits on the wheel well to allow the rest of the air to pass through or vent hot air from an oil cooler. Or you could get a local shop that does vents for hot rodders to do one for you and save some cash
ARC Wind Master
Thanks for your reply guys. If it came like that from the factory i may aswell leave it. Will the ARC vent significantly reduce heat around the intercooler? As Mr Keets & Beer Baron said, I can't see it being very beneficial unless you have an oil cooler.
ARC Wind Master
go down to bunnings and get a house vent cover and cut it in half... $5 / 2 = $2.50
gold.
Femmo - Duno man, doesn't look like tape / butchers paper to me. Looks like black ABS plastic with a grey sheen due to the camera flash... looks kinda factory lookin? lol.
A resonator is a "tuned space" (empty box) attached to the inlet track, used by manufacture to try and tune intake resonance drone out of the system. Theres nothing factory that takes in air from that brake duct.. hence filling it up.
Edited by GeeTR
GeeTR is correct. Some cars have a resinator on the intake before the air filter to quieten the induction noise. It's the first thing I took off my wrx and r32 gtr. I see em as a restriction to the air intake. I would suggest if you got one on your car remove it.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
