Hey all,
About a month ago i purchased a 32 gtr but it wasn't until recently i noticed that the front left air duct is blocked off with what feels like a piece of rubber. Is this normal on a stock gtr? The front bar has been resprayed and i'm starting to think that its been left on afterwards. Would this having any effect on the intake?
Thanks
https://www.sau.com.au/forums/topic/222360-does-this-look-right/
Have you checked to see what's behind the cover? If there's an oil cooler there it's got the cover there to keep oil temps up during winter, and taken off during summer/track days.
During a respray the bar will be removed, so it wouldn't need covers to be placed on it.
I'd remove it, but as long as it's not blocking airflow to radiator/intercooler it won't be a drama.
Got my stock gtr r32 and It also came with the rubber flap. It's factory fitment
If you have a look under ther wheel well plastic lyner you will also have a box resinator.
I removed all those and some more plastic intake crap
Got to be at least an extra 100kw worth of more power now :D
Hey all,
Thanks
LOL that looks like masking tape thats been left on after the respray...
it's factory. you can remove it if you want but just removing it wont do anythnig except cost you some aero.
however your car has definitely been resprayed (and not too well by the look of it). the blanking plate from the factory was just black on call cars. damn, I just noticed they painted the factory lip too. what a shame ;)
well lots of GTRs have had them removed over the years. people remove them, and remove the resonator box behind it too. and the duct can be useful if you put an oil cooler in there or use some pipe to duct cool air up to your airbox/pods. but unless you put either of those in there you may as well just leave the blanking plate in.
Behind the wiper bottle on 32R's is a bung that when removed allows air to travel from the left duct...ARC make a vented plate that fits on the wheel well to allow the rest of the air to pass through or vent hot air from an oil cooler. Or you could get a local shop that does vents for hot rodders to do one for you and save some cash
ARC Wind Master
Thanks for your reply guys. If it came like that from the factory i may aswell leave it. Will the ARC vent significantly reduce heat around the intercooler? As Mr Keets & Beer Baron said, I can't see it being very beneficial unless you have an oil cooler.
ARC Wind Master
go down to bunnings and get a house vent cover and cut it in half... $5 / 2 = $2.50
gold.
Femmo - Duno man, doesn't look like tape / butchers paper to me. Looks like black ABS plastic with a grey sheen due to the camera flash... looks kinda factory lookin? lol.
A resonator is a "tuned space" (empty box) attached to the inlet track, used by manufacture to try and tune intake resonance drone out of the system. Theres nothing factory that takes in air from that brake duct.. hence filling it up.
Edited by GeeTR
GeeTR is correct. Some cars have a resinator on the intake before the air filter to quieten the induction noise. It's the first thing I took off my wrx and r32 gtr. I see em as a restriction to the air intake. I would suggest if you got one on your car remove it.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
