anyone do FMIC installs in melb? r33 gtst?
im not talking about a shop or anything just someone to come around to give me a hand.
im just a bit sketchy of some of the info ive read of some posts on here.
Can anybody shed some light about
1. Do i have to cut anything out of my car body to fit it in?
2. Does the cooler just bolt on with brackets?
3. The just Jap FMIC doesnt have a nipple on one of the pipes that connects to some hose part of the turbo? <---- most confused by this bit
Sorry for the ignorance just don't know a whole lot about my skyline although im slowly learning after having owned it for 3 yrs lol
https://www.sau.com.au/forums/topic/222363-fmic-installs/
If someones going to help you well need some more info. Like what kit you bought. If its the JJ stealth one you dont have to do any cutting on the chassis.
If not there will be cutting involved. You may also need to cut the rio and/or front bar. Brackets if supplied dont usually fit straight up so some improvisation is always needed.
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3918410
Why not just get their kit that goes back into the stock side piping?
Less fitment problems
Less legality problems
All round win-win
thats what im doing now, but when i bought my car we had to cut hole
its neat but now she will be welded up for good :)
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922219
i too want to get the stealth cooler, but i don't think anyone has done an R34 install yet... and i sure as hell ain't cutting up my front bumper, that's for sure.
does mounting it low avoid potential reo cutting issues?
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922248
i dont think you have to cut the reo at all
its ment to be bolt on so no cutting of anything
but its hard to knwo until you find out once someone fitted it to a 34
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922252
I can tell you from expereince that cutting you reo is a BAD BAD idea, even if it's only shaving say 2-3cm off it. If/when you hit someone you'll totaly FCK your cooler, radiator fan, fan shroud, head light mounts, bonnet latch etc etc. That reo does a LOT of work holding everything in place, when it bends it tears shit apart.
Trust me, I know. Go and buy yourself an ARC cooler :(
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922798
^ i was thinking the same thing, surely cutting the reo is perhaps the dodgiest thing you could do, structurally, to a car...
i'm a complete newb to FMIC but would mounting it lower perhaps avoid reo cutting issues??
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922872
I have fitted a stealth kit with very little cutting required.
I installed one in my mates S1 33, It required the bottom section of the bumper reinforcment to be trimmed only, leaving the top section intact.
I will be installing the same kit in my brothers car in a month or so.
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3922936
sorry for the newb questions, but why exactly does the reo need to be cut? what part of the fmic is not clearing the bar?
it doesnt always have to
i had a cheap china cooler before and never had to cut the reo
so im unsure why people do have to cut it?
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3923134
I never had to cut my reinforcement bar either. The core sat nice and tight behind it. Only thing needed cutting was the standard front bar and there was a LOT to be cut out for it to fit.
Mounting the cooler lower will give you problems with the piping if you're not getting it custom made. You could always just use the standard kit piping and flip the cooler itself upside down, but then it'll be dragging on the floor. :(
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3923264
On an R33 the lower part of the reo covers half of the cooler, as does the front bar (S1) . The reason for cutting is to optomise air flow into the core.
https://www.sau.com.au/forums/topic/222363-fmic-installs/#findComment-3923343
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
