Ive got this thing where i want to put an RB26 into a 1978-79 Pontiac Trans-Am. Ive always liked trans ams' ever since seeing smokey and the bandit around 10 years ago. My current love is obviously skylines and thought why not mix it up. What do you guys think of this conversion? Theres room in the engine bay for the motor but would the gearbox fit in or would it need extensive modifications to work? I searched on the net for such a conversion but there doesnt seem to be one yet (maybe for a reason). Can 'haters' please not post responses like "It wont work cause trans ams are shit". ;)
https://www.sau.com.au/forums/topic/222404-rb26-into-a-trans-am/
Anything can be done, with the application of enough money.
American muscle cars should be V8s though. ;)
If I wanted to "mix it up" (I dig old Knight Rider "F body" Trans Ams too) I'd drop in a Lexus or Infiniti V8, and then add boost. :)
there was a guy building a ac cobra here in adelaide when i was building mine he put a turbo rb30 in with autronic inj .
it went bloody fast but sounded so wrong i think craig allan did the injection work and the car owners name was rohan from memorey.
that was about 8 yrs ago i reckon
i was let down so much by workshop after workshop cause i had a gen3 with 6speed manual, and they said it would throw the weight off the r32 if i wanted to do the transplant...
the sound of a gen3 with dropped pipes and the look of a 32, mmmm im gonna have a shower now...
my aim is rb26 into a 240 or 260z. hopefully by the end of next year. need to buy a house first to store it in...
i know it's been done before, but love the look of the car
But atleast its done and proven to be a good combo. Im gonna do some research and ask some workshops what they think about it before i go and buy things.
LOVE THOSE RIMS!!! Anyone no what they are???
this is the qoute from the webpage on that car...
Rollers Street: 18x11 Boze Mesh; 285/35R18 Hoosier Sports Car DOT Radial Wet; Track: 18x11 CCW Classic; 285/35R18 Hoosier Sports Car DOT Radial
http://www.superstreetonline.com/featuredv...ifications.html
Edited by unique1
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
