depending on the trim both do similar jobs, on Rb20 i prefer to use the TD06S-L2-20g (remmeber L2) as it gives the best balance between response and top end. Expect 240-270rkw depending on mods and full boost 1.3bar by 4000-4300.
Forget any other TD06 on there unless you are after big numbers the TD06sh-25g is too big and the TD06S-19c is too small.
Thanks Will dump pipe fit? How much for used ?
Sorry for hijack, but it's on topic.
I thought the TD06 was a journal bearing, and the Garrett's are Ball Bearing.
Would you get extra performance, durability, driveability, blah, blah from the ball bearing model?
marketing hype and nothing else. I sell garret, hks, trust etc and honestley my best advice is to buy a turbo based on its trim and result not the information contained in glossy brochures.
i had a TD06-20g on a rb25 track car that was over 12yrs old that is still going strong.
With regards to which one is better i say the TD06 is about the best thing for a std RB20. A GT3071 is close, from there its really the bolt on convenience of a 2530 etc. So have to question whether the price of the greddy manifold, gate, turbo labour etc etc is worth the extra 30-40rwkws you will get.
The 2530 will have a bit more grunt down low, but when i say a bit i mean a bit, you perhaps trade off 10-15 rwkws at 4,000rpm as the RB20 doesnt seem to want to make power below 4,300rpm no matter what turbo you put on it
So which is better, hard to say, one is more expensive and very illegal, the other is cheaper and can scrape through a roadside inspection
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
