depending on the trim both do similar jobs, on Rb20 i prefer to use the TD06S-L2-20g (remmeber L2) as it gives the best balance between response and top end. Expect 240-270rkw depending on mods and full boost 1.3bar by 4000-4300.
Forget any other TD06 on there unless you are after big numbers the TD06sh-25g is too big and the TD06S-19c is too small.
Thanks Will dump pipe fit? How much for used ?
Sorry for hijack, but it's on topic.
I thought the TD06 was a journal bearing, and the Garrett's are Ball Bearing.
Would you get extra performance, durability, driveability, blah, blah from the ball bearing model?
marketing hype and nothing else. I sell garret, hks, trust etc and honestley my best advice is to buy a turbo based on its trim and result not the information contained in glossy brochures.
i had a TD06-20g on a rb25 track car that was over 12yrs old that is still going strong.
With regards to which one is better i say the TD06 is about the best thing for a std RB20. A GT3071 is close, from there its really the bolt on convenience of a 2530 etc. So have to question whether the price of the greddy manifold, gate, turbo labour etc etc is worth the extra 30-40rwkws you will get.
The 2530 will have a bit more grunt down low, but when i say a bit i mean a bit, you perhaps trade off 10-15 rwkws at 4,000rpm as the RB20 doesnt seem to want to make power below 4,300rpm no matter what turbo you put on it
So which is better, hard to say, one is more expensive and very illegal, the other is cheaper and can scrape through a roadside inspection
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
