TAS_SINFUL Posted June 5, 2008 Share Posted June 5, 2008 just had a desent mechanic from another city look at my car [GTR] as the launceston mechanics fail in all aspects regarding imports compression in cylinders 2,3,4 & 6=150psi cylinder 5 =125psi and cylinder 1 is an outstanding 25psi so please correct me if i am wrong but i believe what i should now be doing is replacing my pistons.? if this is correct ill be looking into getting arias pistons for it as the end goal for me is a 600hp track car. any other recomendations on piston choice or direction from here.? thanks guys Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/ Share on other sites More sharing options...
blind_elk Posted June 5, 2008 Share Posted June 5, 2008 It will depend on why the compression is low as to whether new pistons will sole it. It is apparent that the engine needs to come apart, and in that case you may as well fit some new pistions. But simply fitting new pistons won't necessarily solve the compression problem. If you have broken rings, then new pistons wont fix it. If you have a crappy valve, new pistons won't fix it. The next step is to get a leakdown test, to determine where the actual loss of compression is occuring. Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3919620 Share on other sites More sharing options...
PM-R33 Posted June 5, 2008 Share Posted June 5, 2008 Personally i'd go CP pistons and i think a lot of people would agree. While your at it might aswell do the bearings (ACL race bearings or similar) and see what kind of state the rest of the engine is in. If it's all pulled apart might aswell do it all once now and save any hassels down the track. Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3919728 Share on other sites More sharing options...
race_snooze Posted June 5, 2008 Share Posted June 5, 2008 whats to say its not valves... Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3919856 Share on other sites More sharing options...
Guilt-Toy Posted June 5, 2008 Share Posted June 5, 2008 whats to say its not valves... Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3919887 Share on other sites More sharing options...
sloutch Posted June 5, 2008 Share Posted June 5, 2008 just had a desent mechanic from another city look at my car [GTR] as the launceston mechanics fail in all aspects regarding imports compression in cylinders 2,3,4 & 6=150psi cylinder 5 =125psi and cylinder 1 is an outstanding 25psi so please correct me if i am wrong but i believe what i should now be doing is replacing my pistons.? if this is correct ill be looking into getting arias pistons for it as the end goal for me is a 600hp track car. any other recomendations on piston choice or direction from here.? thanks guys If you are going to build a 600hp track car, you might as well take this opportunity to change the internals. Pistons, rods, rings, head gaskets, etc. Once the engine is out, you should be looking at doing all that and changing your turbos as well. For a track car, you'll need reliability. Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3919888 Share on other sites More sharing options...
NYTSKY Posted June 5, 2008 Share Posted June 5, 2008 You will need more than just pistons for a 600hp track car mate. Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3920375 Share on other sites More sharing options...
Mandi Posted June 6, 2008 Share Posted June 6, 2008 (edited) Where to from here bub? To the land of SR XD hah j/k. We really need a daily driver, with the R gunna be off road and the 200 off road also :S May I suggest we look at pricing and sourcing all the bits as too put into it if your gunna pull her apart That way you wont have to take it off road again and reopen it up? Edited June 6, 2008 by Mandi Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3922560 Share on other sites More sharing options...
grandmasterb Posted June 6, 2008 Share Posted June 6, 2008 As others have said so many variables as to why its low on one cylinder Mitch and without opening it up for a closer look its all just assumptions and guesses for now. Sorry to hear things didn't work out with the tune, sometimes its just not meant to be hey I agree with CP over arias pistons, also if your wanting that 600hp track weapon (little overkill but anyway ) then like suggested the motor is open so you may as well do it all in one hit: Pistons bearings rings head rods/bolts metal head gasket head work (most likely needed) oil pump etc your always going to be up for BIG $$$'s when it comes to a 26 rebuild so dont rush into anything, look at all your options and have a look at 26 results thread and you will see what others are making with minimal mods Good luck with it Ben Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3922670 Share on other sites More sharing options...
R31Nismoid Posted June 6, 2008 Share Posted June 6, 2008 Where did you send the car? Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3922940 Share on other sites More sharing options...
blitzxtr Posted June 6, 2008 Share Posted June 6, 2008 Everyone seems 2 like cp pistons what about Mahle Pistons there great teflon coated they look apart except for fitting requires a few mods to oil squirters but overall they are good couldnt say there better or worse than cps as ive never used them in my engines. Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3922969 Share on other sites More sharing options...
PM-R33 Posted June 6, 2008 Share Posted June 6, 2008 (edited) Not that this has anything to do with RB engines, but ive heard that Mahle were great back in the day on old iron blocks but on modern alloy blocks they dont seal as well or something along those lines? I know our blocks are iron so maybe they are fine, but on something like a SR which has a allot block SP pistons are pretty much the pick of the bunch and most people i know use them over Arias, Mahle etc. Edited June 6, 2008 by PM-R33 Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3922993 Share on other sites More sharing options...
blitzxtr Posted June 6, 2008 Share Posted June 6, 2008 Did ya know BMW use mahle pistons on there engines today they never have a problem with sealing & there alloy blocks Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3923015 Share on other sites More sharing options...
PM-R33 Posted June 6, 2008 Share Posted June 6, 2008 Hmm yeah true, forumla 1 teams use them aswell i think. I swear i heard something about the use of Mahle pistons and something about them, ill find out later... Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3923046 Share on other sites More sharing options...
blitzxtr Posted June 6, 2008 Share Posted June 6, 2008 Hmm yeah true, forumla 1 teams use them aswell i think. I swear i heard something about the use of Mahle pistons and something about them, ill find out later... Yeah Ya right F1 use them. Some WRC cars as well as Nascar Link to comment https://www.sau.com.au/forums/topic/222422-where-to-from-here-bad-compression/#findComment-3923062 Share on other sites More sharing options...
