Anyone down in Wollongong with an R33 S1 Manual? Could even be S2, not sure if the ECU's are interchangeable, but...
I'm after a stock ECU to plug in and test, just need to check if it works, you can have it back straight away. :3
Currently running a Power FC, but need to test out with a stock one that I know works.
I've got one at home, but to be honest I think it's ratshit, plugged it in and when I turned the key to ON, the HICAS system just whirred like a bitch constantly, the AVCR lights would come on (as usual) then off, then back on solid, and I can't get the car to kick over when I turn the key.
Anyone who can help would be hugely appreciated, if you're able to help please PM me. Thanks!
https://www.sau.com.au/forums/topic/222424-need-a-bit-of-help-wollongong/
what does it do with the fc for a start? i have one here in campbelltown im not using
The PFC, you turn it over, works fine. No HICAS whine, AVCR lights up fine, kicks over first time. Reason I'm taking it out is for fuel economy and cash, I don't have the money to get it tuned (it's a hand-tune at the moment, farking terrible). Also lumps at traffic lights, yay for hunting. All in all the car still goes, I just want no lumping, good fuel economy, and back open to 7k RPM. Without spending moneh on a tune. :P
sounds like your stock one is cooked then. i cant think oif any reason y it wouldnt ar all when the fc does. its usually the other way around
well if you want to come up and try, thats fine im happy to sell it too. but im not driving down there :P
Hey mate - It may be worthwhile calling bezerkly - they mod heaps of skylines and may have a spare ecu hanging around.
tell them Jase sent you.
Might do that, the only problem being that I work all week including Saturdays, makes it kinda hard to see the guys there. I know they do great work; a mate's S15 Autech went there for a service, was awesome. I'll give them a call anyway and see what I can organise.
How did it go owen?
Yeah, she's goin good. Still idling a bit high every now and then; I turn on the car, she'll idle at 1400 or so, take her for a drive and it'll idle at 850 when I get home. I think the turbo is making a bit of an odd sound at WOT in 2nd, but that's to be expected; I've gotta get it all checked out. All in all, fuel econ seems heaps better, I hit 220 before the gauge started coming down instead of the usual 170. :D
GOOD NEWS! let me know if you need anything else i have a lot of crap here lol.
you could try checking the aac, there a re a few threads in the diy section. im not sure its the problem though, and would try adjusting the idle as nissan intended first especially seeing as how you've played with the thing
    • Hmm makes things tricky then.  I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.  But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.  If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?  Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
    • Ok so I will not defend my naivety. I regularly feel like things look easier than they are.  As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
    • If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.  I've seen professional welders do similar but easier repairs and still end up with warped panels.  It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.  Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.  Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
    • I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.  I'd prefer some ugly metal fab than anything weak.  I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
    • Ok, thats a good starting point.  So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right? Before we look at other options, how confident are you welding?
