i'm off to get my 2835 installed in a couple of weeks so i decided to do a few of the less time consuming supporting mods myself... (fuel pump etc)
so i installed some new splitfire coils and some bcpr7es gapped to 0.8... and put the car back together
when i took it for a drive i noticed 2 things...
1) it feels smoother and more linear throughout the rev range
2) its running less boost. ?!
formerly i was getting .9 bar with boost controller (bleeder) switched off but spiking out to 1.1
now its getting .5 bar and not spiking past .55
so i turned up the bleed valve to .8 bar and it holds nicely without spiking past .85ish
car has pfc, fmic, turbo back etc. how much boost shold it be producing with these mods?
also when the car was tuned a year ago @ racingline, nige said there was a tiny leek that he didn't have time to locate,(i needed transport back) but the car was running fine and not to worry. the car ran strong for a year with no problems.
so... my question is this...
was the car running with a leek that was acting like a bleed valve and upping the boost for a year
OR
did i not put a hose on properly this time? (i have checked and checked again...)
https://www.sau.com.au/forums/topic/222437-interesting-problem/
Oh and they're gapped to .8 cause i've been told by many many people that would be the optimum gap...
On a stock ecu/tuned car running 98ron yes
With an aftermarket ecu, tuned and new splitfires your gap should be 1.1..
The idea of setting the gap to .8 is a cheap get around for the pinging/breakdown issues most skylines have on 98ron when using the factory tune.
It's a stop gap, for peeps that can't do it the right way atm...with your parts you shouldn't be bothering with that crap.
Embrace the strength of a bigger spark!!
I did the same thing when I first got my nissan, until I got around to doing it right.
i dunno... taking all that shit off again... might give it a go when i get round to installing those injectors that are still sitting in the box next to my bed :thumbsup:
any ideas on the prob guys?
Even once the coilpacks are "coated in silicon" the car will fart and miss above 5000RPM if you gap is at 1.1mm WHERE IT IS MEANT TO BE!
Once you chuck the Splitfires in, (Or even BRAND NEW stock coilpacks) you will be able to gap plugs to 1.1mm AND rev to redline perfectly cleanly, producing a better flame front in your engine.
Technically, from what I can gather, it will also allow you to run slightly more advanced timing when you do the tune, as you have a wider initial flame front.
Hence @ 1.1mm you should be able to make more power cleanly...
Depends on a variety of things but, in this case the 0.8mm gap is going to be better at high rpm/boost and power levels in terms of reliable spark.
1.1mm is a nice gap for a cleaner burn at lower rpm, hence it's factory.
The factory coils are just as good as splitfires by the way. Splitfires are just cheaper to buy new.
How do you figure a smaller spark is better on higher boost?
Gapping down is a very basic and simplistic way of advancing timing...used to get around pinging on a stock non-tunable ecu.
If you tune the car correctly with 1.1 gap it is better...you can actually feel the difference in top end, revs more freely.
Splitfires don't create more horsepower, but they do give a stronger spark (%20?) which certainly helps.
But hey if 8 is your lucky number.... who am I to say different.
I'm sorry but, 'feeling the difference' in top end?
Unless the tune was rooted before I can assure you that not only is there no power difference but, also this 'feeling' is peculiar only to cars that started out with a spark issue or were seriously 'under-gapped' for the density of the air/fuel mixture.
Smashing more power/rpm/boost into a motor and gapping down on the exsisting heat range is tuning 101( for all cars). If you get no joy in the top end after gapping down on the exsisting heat range you go to a colder plug etc.
For example, for most of the NA V8's I've tuned you can just about go off a rule of thumb that is gap down 4 thou for every 50hp added.
I've been doing this to alot of different cars over the years so 'luck' has nothing to do with it. :)
There are some serious horsepower GTST's & GTR's running around with factory coils as well. Splitfires do one thing well and thats make a cheap replacement for the expensive factory coils when they are shagged. :D
Edited by rev210
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
