Originally posted by EVOIV
I admit that the R34 GTST doesn't look that great, and maybe the series2 R33 might even look better...standard. But just WHO leaves their skyline standard? There are so many bodykits out there that any of the skylines can look equally as good as the other.
Mine's stock, not even sideskirts :) Well, it has the bigger front bar, that's it. Of course if it looked ugly when stock I might have done something about it sooner.
  • Replies 109
the r33 skyline has a slightly better power to weight ratio than a silvia/180sx and better still after applying common mods to both., but who is going to be quicker, i think the silvia/180sx may get the skyline of the line because of the lighter weight to get it going but the skyline should get it over the 1/4
(but it also comes down to who is driving)
I'm pissed off, i went cruising tonight and i lost everytime!! mind you i wasnt racing riceboxes...now im starting to think something is wrong with my car hehe
Its probably just me though, i havent owned the car long and plus its auto so i cant rev it up much at the lights and dump the clutch to get good launches.
oh well fmic and s-afcII is on order im hoping that will give me enough power to keep up with most modified cars around
MJ, Stall it up at the lights, just before it goes green (dont be a fool and hold it for 10 seconds! LOL) Now got boost and revs... and you'll launch just as good as a manual! And even better than a manual in some cases...
Btw maybe you should put it on a dyno to check out whats going on!
At a club day at Oran Park i was hosed by a turbo MX-5, 180SX with Apexi turbo, S14 with cat back exhaust, M5, but i beat a calpped out 4cyl Pintara :) At the time i had cat back, filter and IC running around 12psi.
But on the slalom and driving events i was in the top couple of cars, so R32s may not be straight ahead demons, but are well balanced with good brakes and are good alround performance cars...well in my opinion.
Yeah Busky2k, I found the best method is to put my left foot on the brake and right foot on the accel and rev to about 2k then launch. Is this the best method?
Any higher revs and i just lose traction and wheelspin through first. My rear tyres are a shitty tyre though... so i think if i get some quality tyres on the back and perhaps some pinapples (im not sure if these would do anything?) that would help alot.
I never realised how quick those genIII commodores are haha i get hosed by them everytime...i havent raced a stock one yet so maybe i could keep up with that.
This is my first decent car and its lots of fun having good runs with other good cars
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
