Hey guys im building an rb21det for my r32 gtst im over the ditch in NZ and havent heard much or cant find much info on these engines... anyway ill rattle off da specs :)
rb20det block bored to 2.1 litres
port polished head
standard cams reground to 264degree specs
custom wiseco forged pistons
forged h beam rods
trust metal 1.5mm headgasket
SSi stainless steel manifold
Garrett GT3040R turbo .82 exhaust housing
44mm Tial wastegate
blitz dual sbc
trust airnx filter
550cc injectors
Greddy emanage ultimate
full 3inch exhaust
DSR front mount
sard fpr
external coils and leads
walbro 255 internal fuel pump
ACL race bearings
prob something else engine wise but bet i left it out haha... anyway now for the questions, im aiming for 300 to 350 rwhp id think i should be able to achieve this with current mods, im a apprentice mechanic at a performance garage so i have a fair idea about stuff... also has anyone had experience with the emanage ultimate? you reckon it'll be fine for my application? i like the fact that its a piggy back but have heard mixed reviews for it... also does anyone have experience with the GT3040R? do you have any idea when boost will come on? i know she'll be laggy but i like that :P but should be a lil better than a rb20 because of 2.1 litres and headwork right? anyway ill post pics of the build and keep you updated with wat it does on the dyno just waitin for rotating assembly to be balanced, well cheers for your time any comments and advice would be appreciated! :P
Edited by vr4ust
https://www.sau.com.au/forums/topic/222505-what-you-guys-think-of-my-rb21/
RB21 + 3040 + 0.82 is gonna be a light bulb and that turbo combo way too big for 300-350rwhp. Have you bought it already? A 3071 0.63 would give you that power easily and be much more responsive and make a much faster car too.
go with a .63 rear and it will be fine, not laggy and not snappy power.
my motor with the 3040 .63 and stock internals apart from the fitment of 264 9.1 hks cams made 346rwhp at 22psi on a tired motor.
if your going to build the motor im more than confidant you'll make the power easy!
Yea already have all parts just waitin for rotating assembly to be balanced, yea i thought it was a .63 but looked inside it says 0.82in inside the exhaust housing, so far too big you reckon? what sorta revs would full boost be comin on at? ill prob look at something smaller although i dont mind a bit of lag like full boost 4500rpm max haha...
Hey wat rpm does your car come on full boost? wats your rpm limit set at?
sneak some compression? its gotta 1.5mm trust metal headgasket but the pistons are domed, would be interesting to see wat the comp ratio would be? hey have you got that grey r32 with black front kit on youtube tdo6? f**kin loooooooove that car spesh the video where it takes off and you almost dont make the corner and do the styley 3rd gear escape :) was sick!!! (hope it was you im talking bout haha) o and wat you think of the .82 exhaust housing far to big?
thats gonna be de-comped a fair bit.
I was seeing fullboost around 3700 on the tacho in the car in 4th gear it was more like 3500 and limiter is set to 7000 cos there was no point reving it to hard if it wasnt making anymore power..
82 is large but i wouldnt underestimate it just yet until you try it on the car, swaping the rear housing over if its too laggy isnt a stressfull job so my advice is just try it first
looking over your mod list again i wouldnt rule out 400-450hp when leaning on it, swapping the rear housing wont make you loose power, it will just shift the point it takes place
If you only want a max of 260rwkw, ditch the GT30/.82 idea. Get something like a 3071 with a .63, will meet your target and be MUCH more responsive
Or something - TD06 like tRoy :) Its a great turbo for the RB20
sounds like me if i am missing corners :D
As Ash said the 3040 is capable of 330-350rwkws which is going to take lots of boost and revs in an RB20. Even with the smaller exhaust housing its not going to have great transient response (throttle response) I would be inclined to try an external gate 3071 but probably a 3076. 3071 will be punchier then the 3076 but will not comfortably make over 260rwkws. 3076 will see you in the 280-300rwkw area which if the motor is rebuilt with pistons will do quite happily. Remembering the 3040 isnt a great turbo even on RB25s etc where over the years ppl have tended to steer clear of them and go 3076, so if an enbgine with 9.0:1 compression and an extra 500cc cant get the best out of the 3040 then the RB20 wont love it.
That all said do a search for Legend01, he ran a 3040 on a std RB20 then a forged RB24 and quite liked it, so woudl copy the trim and spec 3040 he had
Headwork can help make power, but at the same time get it wrong and it can cost you some low rpm velocity which again hurts response. I would stick with simple match porting and basic cleaning up casting imperfections. With regards to cams i would stick with std then after the setup is sorted maybe try the smallest Tomei Poncams (256 duration). This way you can see if they help, if so keep them , if not sell them for only a small $ loss.
Personally if you already have the 3040 then sure keep it.
Looks like a good engine combo but its interesting that you decided to regrind the stock cams straight off the bat???
Im looking forward to seeing the end results as its somewhat "similar" if my motor lets go again :(
OT: Adam i noticed you said you had HKS 264 cams with 9.1mm lift, are you positive they are 9.1 or 9.0??? Reason i ask is that i've got the same cams that im about to drop into my stock 20 and spec sheet stated 9.0mm direct drop in meaning not needing upgraded valve springs.
Cheers Ben
Yea i brought the block and head already done so just gonna chuck it in see wat happens! hey so this legend guy has already put a .82 gt3040r on a rb21?? i should def get hold of him, so any ideas wat i should be able to get outta this engine with some sorta decent reliabilty? i know im asking how long a piece of string is but my engine fully forged so im guessin 350 to 400 rwhp should be good although i have never really heard of many of them get much higher so it must be pretty highly strung by then?
yea i have thought of that but i like the 21's and already have all the stuff love the sound of the 20 and figured the 21 would sound the closest haha
An RB24 doesn't really sound any different to an RB20, still revs the same, just a bit angrier.
Cheers
Gary
i reckon closer to 5000,
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
