what should my car run E/T with good grip
R32 gtst mods are rb25 conversion ,fmic 600,300,70 hypergear kit ,turbo back exhaust 3"
blitz bov pod with cold air intake with head light out 12 psi with turbosmart boost T
tyes 255/40/17
should it do low 13
what do you guys think about a 12.9
i bet a typhoon they run 13.7 stock
Edited by RB SANDY
https://www.sau.com.au/forums/topic/222538-what-should-my-car-run-et/
u could look at a mid 13 to low 13 u mite be pushing any 12 but it all the driver and a good take off u could hav 2 drivers same car 1 get a 15 1 get a 13 so noone could giv u a good answer but the car should be capable of a mid 13
it is a how to guide but it is the driver. u could get a better time but have more power in a lighter car your next prob is traction. i got a 32 gtst when i ran mine had about 190 rwkw and ran a 13.5 but bad traction launched at to high revs. does the how 2 guide tell u what to launch at because what if 2 drivers do differant launch 1 at 4g and 1 at 7g they both goin to get 13.4. it just doesnt make sense but best way is run it u mite surprise yourself and get a 12 i hope u do. just run it a thew times each launch at diff revs to test it out
lol 40 profile on 17inch rims is only gonna get your mates going "pwoaahh sandy you got no traction down the quater" lol, get some nice street/racing slicks, and then what ever you run will only improve on the launching department, as your traction department will be covered...
when you do end up taking it out, post your time on here. i keep meaning to take mine out, but little things just keep going wrong.
got a boost leak at the moment.
before that it was the rear camber
and before that it was the clutch
and so on and so on.
never anything major, but enough to keep me away from the track.
my younger bro ran a 13.3 with simular mods to you in a r33 with a 2.0s 60 foot time.
If you can drive it hard and launch it well (his tyres were shit so theres no reason why you can better his 60 foot time), theres a good chance for a very low 13 pass. Put slicks on and launch it hard and a high 12 should be on the cards.
Edited by R34GTFOUR
I'd say mid 13's should be on the cards at least - From what i remember a few years back when i got a seat in that thing it was mighty quick and had me smiling for a while :happy: BTW, I'm your mate Steve's cousin if you remember.
I'm hoping to tap into the 13's with my car:
stock RB20
+ 3" split dump&front / high-flow cat / 3.5" cat-back
+ FMIC
+ bosch 040 pump
+ APexi power intake
+ remap (boost restrictor/speedcut removed + ignition timing advanced with new fuel map)
160kw atw before remap, was quoted a 10-15kw gain after remap & between 10-12 pound ATM - car running extremely well.
Cheers,
Steve.
years ago when my 32 had an rb25 with 190rwkw std rb25det unknown ks 3in turbo back, pwr intercooler,microtech ecu 11-14psi no difference. run between 13.2 to 13.4 all day on 225 street tyres 108mph i think.would just break into a 12 with m/t street slicks id say
got walbro myself. nice and quiet, and also reaches to the bottom of the tank, so can use the full tank of fuel, as oposed to 3/4 of it.
as soon as i find this damn boost leak, will take my car down to the quarter. expecting mid to high 13's....
at the moment replacing the front bushes, so won't be fixing the leak for at least a month or so. budget just does not allow it.
You wont need 230 at all.
I ran 12.9's @ 109mph all day long (lots of practice and i was very consistent back in the day)
And that was with 220rwkw, RB25 in a car over 1400kg (HR31 GTSR)
This was using 225 Simex tyres, nothing special, nothing thick.
R32 is lighter by a reasonable margin, it should be able to do it with 200rwkw.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
