Have you altered the boost level?
Given they are likely much the same overall in terms of mass airflow capability, unless you've fundamentally changed something (ie the mass-flow), then the ECU mapping should cope easily with a change from high flow to high flow. That is running on the assumption your existing tune is not overly lean or aggressive on the ignition.
That said, half an hour of dyno time is a cheap way of optimising for the slight spec change. Might also show you where relative strengths of one setup vs the other is. :(
https://www.sau.com.au/forums/topic/222545-re-tune/#findComment-3922442
I think because its a completely different turbo, flows different also, probably best to get it retuned for best results or at least put on a dyno and have it checked over to make sure the tune is still safe and its not leaning out/running to rich etc
https://www.sau.com.au/forums/topic/222545-re-tune/#findComment-3922465
Yeh the bb gcg seems faster spooling and i thinkit is a stronger turbo however ihaven't really driven it much just a quick run than home! i think i will book it in for a retune at mercury. thanks guys just annoying having to get time off work to book the car in and i have been missing boost! :)
https://www.sau.com.au/forums/topic/222545-re-tune/#findComment-3926934
Go to work, ring up from work, book car in.
Drop car off one morning before work, pick car up that afternoon after work.
Where was time off?
https://www.sau.com.au/forums/topic/222545-re-tune/#findComment-3927062
