Australia's fastest GTR is on track to run a 7 sec pass this weekend at the winternationals. With a lazy launch 1.35 60' and wheelspinning on gearchanges the car stopped the clocks at 8.16 and blasted through the traps at 171MPH into a strong headwind. With further setting the car up for the conditions and a better 60' (PB is 1.23) a 7 sec pass is obtainable. Further updates will follow tommorrow night with the 2nd round of qualifing to be held at 7pm.
well done to Mark, Justin, Harry and the team (Julie, Tommi and Ava)
Edited by DiRTgarage
  • Replies 52
Very cool - good luck guys :D What tires is it running on now, I am assuming full slicks?
***UPDATE***
Tonight in the 2nd round of qualifing the car ran an Australian record equaling 8.07. MPH was 173 with a better 60' of 1.27
Car was turning the tyres hard off the line but due to the lack of a slider clutch is something that will have to be put up with. Car is unloading the tyres front to rear after grabbing 2nd gear but is running straight as an arrow (unlike sydney where it wanted both lanes)
Lambda readings on the MoTeC show the car is running rich in the air conditions at the track. A harder leaner tune will be tried tomm for a shot at the elusive 7.
stay tuned
Awesome, exciting stuff :D 173mph is certainly getting up there, fingers crossed it can get those extra few mph and a 10th less - would really like to see this car as the next 7s one!
Good luck guys.
right...the 60' was 1.27 so up there but not quite a PB. Mark hit the limiter in 1st so even quicker times are on the cards in the finals tomm. Car was gunbarrel straight and in the groove the whole run with a 1/2 track MPH of 141. MPH shows 7.80's are achieveable in the eliminators tomm.
This makes the car the 3rd fastest GTR in the world and the quickest 2.6ltr RB 26 in the world.
Awesome! Congratulations! :) look forward to hearing how it goes tomorrow
Just got back from the track. Mark's 7.96 @ 176mph was awesome!!! 60 was good then he banged off the limiter. It ran straight.
I recon closer to 180mph with a high 7.8x tomorrow!!! fingers crossed
CONGRATS TO MARK & TEAM!!!
woooooooohooooooooooooo!!!!!!!!!!!!! bout bloody time!
awesome work and congrats to all involved!
paul what time does he run tomorrow? i'll be out there all day from mid morning on
his first elimination round is at 10.25am
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
