Hey im looking for some advice
Last night i installed a HKS2530 with 3" dump on my R32.
The turbo works a treat it pulls so much harder than the standard but i find at around 6,000rpm the engine cuts out completely.
it really freaked me out. I am running the same boost as i was with the std turbo (1bar).
So i decided to remove the bleed valve completely. it doesnt stall anymore at high rpm, but i do find the boost tends to creep above the 0.7bar... somtimes almost to 1bar.
*note: i am running a completely std computer.
so i have a few questions:
1: would the cut out be a fuel cut or something else?
2: is boost creep normal? it never happened with the std turbo.
3: even if i run standard boost is it possible for the car to run lean? does more dense air need more fuel?
any advice/info would be great!
thanks
Ben.
https://www.sau.com.au/forums/topic/22256-high-rpm-engine-cut-out/
im not very up to date with skyline ecu's etc , but with ur new turbo , it may reach the same psi , say 14 , as ur other one did , but the volume of air being pushed in will be far greater , due to the larger comp wheel etc etc etc.
therefore too much air , not enuf fuel , the computer might know to shut itself down before something bad happens , like i said i dont know much about skyline equipment so i am probably off track
yeah when it cuts out i mean it completely cuts out. like under full load its pulling really hard then all of a sudden nothing... as if i took my foot off the accelerator. it doesnt "die out" as such, it just cuts out very suddenly.
Sound more like fuel cut from overboost. You are probably not running the same boost after fitting a dump pipe. ie. Less back pressure=higher exhaust speed=more boost.
The solution is to lower boost until it doesn't happen, OR get a fuel cut defender combined with refueller (AFC or piggy back) to make sure you are not leaning out up top. Maybe the TSI which does both.
OVL-747... i have heard this before but get confused. i always though 14psi would be 14psi regardless of the type of turbo as pressure is pressure ie psi = pounds per square inch so regardless of what is producing that pressure it is infact the same pressure (does this make sense?)
however i do understand a bigger turbo will produce that equal pressure but the air will be much cooler. and cooler air is more dense...
so when ppl tell me that my turbo is producing the same pressure but pushing more air is that what they mean?
yes 14psi is 14psi , but there is a greater volume of air being pushed in , still at 14psi though.
its very similar to an oil pump , take and rb30 and an rb30t pump , they both have the same oil pressure , but as the turbo pump is bigger it flows that wee bit more oil , needed for turbo etc but still at the same pressure
yes - thats why it is extremely common to "hiflo" a turbo , basically , the larger wheels can push a larger volume of air , but it still enters at 14psi.
the more air (mixed with proper fuel setup of course) means greater combustion = more power.
but in ur case id say the computer may be sensing too much air , not enuf fuel so it cuts out intermittently.
Bbenny, I seem to be experiencing the same problem, just put in my 2535 and it does something very similar at about 1 bar it reaches full boost at ~3500rpm and then seems to bog down till it reaches ~6000rpm and then goes hard till rev limiter.
I can hear the turbo working hard but it doesnt seem to pull as hard as it should.
I boosted to 1.4 bar and when it reached ~4500 it fully cut out like when you hit speed limiter, so im tending to think it would have to be not enough fuel going in....
Might get it Dyno tuned and see how it goes maybe then get a bigger fuel pump...
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
