ok, tried for ages to find a c spanner for my hks hypermax coilovers, seems no one stocks them or its just too damn hard... :D
So my question here is, HAS ANYBODY GOT ONE I CAN USE FOR THE WEEKEND... NEED THEM ASAP
My car is so close to going over pits, and this is stopping me!! :)
If so gimmie a call on 0404726323
Cheers
Guy
https://www.sau.com.au/forums/topic/222566-c-spanner/
Call R_DIRTY_3, Brad. He works with these everyday! He might have SOMETHING that resembles a C Spanner :(
I do!
I have 2 options for you. I have some new ones i can sell you, OR i can lend you a set. However, i do require a $50 to guarantee return....Not saying i dont trust you, but ive lost several sets in the past. $50 will be given back to you when the spanners come back :(
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3923370
thanks alot guys, Brad?... i just sent you a message, but if you read this before... will they definatly fit my hks hypermax??
I'd prefer to buy them hey... but if you have none in stock then ill just borrow for now... either way, when can i pick it up?
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3924729
nah they not that bad, lasted me a few goes....
only thing is, your knuckles cop a good beating when the spanner tip wears.. heh
Thats why you should buy/use decent quality ones. Your poor knuckles dont deserve that lol
The Tein C Spanners are probably the best on the market.
With a specially designed hooking part they can be used to adjust 70, 90 and 132mm spring seat/lock rings.
They also have a 12.7mm hole so if you really need to use a lot of force you can use astandard breaker bar.
And as the material is only 6mm thick, it will locate into lock rings, with less chance of slipping out, than others that are claimed stronger at 7 or even 8mm thick.
So there ya go. Lesson 1 in C Spanners :D
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3925527
Big thanks to Brad... was going to borrow but figured ill need more than one use out of them especially for those times when the po po try to yellow my car... no sir i will raise it right now if you like...lol, so yeah, i thought id just buy em...
Thanks again!!
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3927146
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
