ok, tried for ages to find a c spanner for my hks hypermax coilovers, seems no one stocks them or its just too damn hard... :D
So my question here is, HAS ANYBODY GOT ONE I CAN USE FOR THE WEEKEND... NEED THEM ASAP
My car is so close to going over pits, and this is stopping me!! :)
If so gimmie a call on 0404726323
Cheers
Guy
https://www.sau.com.au/forums/topic/222566-c-spanner/
Call R_DIRTY_3, Brad. He works with these everyday! He might have SOMETHING that resembles a C Spanner :(
I do!
I have 2 options for you. I have some new ones i can sell you, OR i can lend you a set. However, i do require a $50 to guarantee return....Not saying i dont trust you, but ive lost several sets in the past. $50 will be given back to you when the spanners come back :(
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3923370
thanks alot guys, Brad?... i just sent you a message, but if you read this before... will they definatly fit my hks hypermax??
I'd prefer to buy them hey... but if you have none in stock then ill just borrow for now... either way, when can i pick it up?
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3924729
nah they not that bad, lasted me a few goes....
only thing is, your knuckles cop a good beating when the spanner tip wears.. heh
Thats why you should buy/use decent quality ones. Your poor knuckles dont deserve that lol
The Tein C Spanners are probably the best on the market.
With a specially designed hooking part they can be used to adjust 70, 90 and 132mm spring seat/lock rings.
They also have a 12.7mm hole so if you really need to use a lot of force you can use astandard breaker bar.
And as the material is only 6mm thick, it will locate into lock rings, with less chance of slipping out, than others that are claimed stronger at 7 or even 8mm thick.
So there ya go. Lesson 1 in C Spanners :D
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3925527
Big thanks to Brad... was going to borrow but figured ill need more than one use out of them especially for those times when the po po try to yellow my car... no sir i will raise it right now if you like...lol, so yeah, i thought id just buy em...
Thanks again!!
https://www.sau.com.au/forums/topic/222566-c-spanner/#findComment-3927146
    • I know that smallbox is not great but as i said it will be for a limited time and iam not going to get crazy. But thanks...i just want to know if i can use that clutch and not have "problems"
    • No no. The Audi boost controller was made from a Norgren (or equivalent) 1/4" pneumatics pressure regulator, a similar (looking) relief valve (to create the "gated" function to keep the boost off the actuator until wanted) and a check valve plumbed in parallel with those two, to relieve the boost back out of the wastegate line after the boost event was over. It was the inclusion of that check valve, used sort of "backwards" as a relief valve, that was the stroke of genius that made the rest of it work nice. The only reason I stoped using it was because it was like any other manual/pneumatic boost controller - it's settings changed from season to season. The Profec is much more consistent winter to summer.
    • A couple of months of gentle driving will be fine. There is a risk that you will kill it. A heavy workout will probably kill 3rd gear. Continued use will wreck the input shaft bearing.
    • That's because R34 RB25DET is a pull clutch gearbox. I have that clutch, behind 25Neo, in front of R33 gearbox. I have brand new R34 turbo gearbox, in a box (cardboard) in the shed right now, and it will be getting used with the same engine and clutch, because I also have, in a much smaller box next to it, the front plate to convert the new box to push clutch.
    • Are you planning to ever come on boost with the RB25DET? The torque of the motor alone will break the little box. It's not a matter of if, it's when.
