hey guys i got a ppg straight cut dogbox and using the redline lightweight shockproof in it at the moment, im finding when its cold it drives smooth as but once warm it tends to crunch abit even when driving it hard, its a very very new box so shouldnt be anything wear and tear related i hope, im thinking either the oil is wrong type and getting too thin when hot? 1st to 2nd when giving it a boot full is a big cruncher too i cant stop it :)
any info appreciated
You have a dog box and your worried about it crunching? Am i missing something here?
Maybe he's referring to a straight cut gearset (ie. first 3 gears replaced).
unique1 are you referring to a dog box or straight cut gearset?
:Dave here:
Thats just the way they are. id be using a heavier oil. ie heavy shock proof. thats what i use.
1st to 2nd is always harsh, you will need to revise your driving style .
the oil is nice and thick so the gears slow down quicker till everything heats up.
they are a pain to rev match. just practice dude.
yes its a ppg 1st to 5th straight cut dogbox, i know they arnt a smooth ride but i was just curious as to why it was perfectly smooth when cold but worse when warmed up. Thanks Dave, i just wanted to make sure its nuthin bad and im causing more damage, ill swap the oil over asap and see how it goes, i can get it to drive smooth as without any crunching except the 1st to 2nd shift :) if i go slow 1st to 2nd its fine but when revving it right out it crunches bad.
im definately getting the hang of it now i dont mind driving it at all even around the streets its fine and just has abit of a whine too it that gets on ya nerves sometimes lol :thumbsup:
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 😢
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
