gee i dont know where to start but due to a back injury thats not going to get any better and is deteriorating rapidly i reluctanty place my 18 ft nerues on the market .
ok it;s a 18 ft runabout with the motor mounted on a pod the amount of fishing room in this boat is amazing . the motor is a cv yammie 115 hp ie it is a premix motor that i actually prefer cause at least when i mix the fuel up i know the oil is in there .
i am the second owner and the boat has spend it;s life under cover in a shed since new it has done just over 500 hrs since new both boat and motor . it comes complete with canopy and clip on side clears / 90 litre under floor fuel tank / 2 huge under floor storage area's.
all saftey gear lifejackets / epirb/ flares/ gps with lots of pt huges snapper and whiting marks left in it / colour sounder / v sheet/ torch / hf 27 meg marine radio and also vhf marine radio/ comes with a muir electric anchor winch about 1400 bucks to replace /custom made alloy bait board .
boat has full night lights navigation and cabin .
the 2 heavy duty marine batteries where replaced at christmas and have done just 2 trips there is a battery isolater switch to select either of the batteries or both at the same time .
there is a water trap fuel filter in line from the tank to the motor
the boat is in quite good condition and is a clean tidy unit .
the trailer is a single axle dunbier that i have modified and it tows great will sit on a 100ks behind a falcon wagon and we towed it down to edithburg on many occasions. it has been fitted with new disc brakes as documendet on fish sa when i was doing it and the same time i lenghened and reinforced the draw bar .
there is a electric winch to pull the boat onto the trailer its a bit slow but does the job the trailer is drive on but ive never been game to try it lol .
the trailer has 3 brand new 8ply light truck tryes with the spare mounted and locked onto the trailer . the trailer has just had new marine waterproof lights fitted to it
ok for this gem i want $24.500.oo i am not interested in trading smaller boats due to my back injury and im not in a hurry to sell it for much less than that i know there hard to find in clean condition cause i looked far and wide till i found this one
i can be contacted thru here or you can ring me most times on my mobile 0402 258352 if you would like to arrange a viewing or just have any further questions
regards squidley aka dean
http://s290.photobucket.com/albums/ll262/squidley_photo/ i will endevour to get some better pics when im well enough to get the boat out of the shed
https://www.sau.com.au/forums/topic/222579-18-ft-nerues-boat/
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
