Morning all,
well i was riding to work this morning, in the shit weather, just taking my time... when this van started following me...
i didnt think much of it for a while, thought it was a delivery van... then i went a different way, out of the normal path... then back onto it... van still following me....
now it was wet so i couldnt exactly out run them or i would have more than likely had a stack... so i kept going on my merry way to work trying to keep some pace up and look out for a cop or anyone to help me......
I got to a big set of lights and unfortunately i had to stop.. just before i came to a stop i realised that there were 3 dark figures alrady running up to me, they had jumped out of the van already before it stopped and ran up to me...
One grabbed the handle bars, the other grabbed me around the neck and tried pulling me off, and the third was punching me in the guts.....
I headbutted one with my helmet, i elbowed the guy that was punching me and then the guy that was holding the handle bars i gave him a quick jab in the nuts with my nice solid boots.......
I quickly dropped the clutch and skidded myself off the lights, i had a nice dry tunnel up ahead so i totally gunned it through hopefully slowing down in time for the speed camera!
Anyways just as i was beating these guys off, i noticed that one had some crazy 80s tats on his arm and what not, another guy smelt like spew so badly, and the last guy was some small asian guy....
so Sammeh, sorry about the headbutt dude, doof, sorry about the kick in the nuts (did i even get them), and vicktoorrrrr sorry about the elbow bro.....
to everyone else
TGIF
MUDDAFARKERS
LOL
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
