The temp gauge on my Non-turbo R33 sits below the quarter mark, even in city traffic. It warms up to this temp quickly enough, but never rises above this, even with AC on. I'm thinking this could be contributing to my bad fuel economy (400km to the tank), running cold would be running rich right?
Any ideas what i should look at?
Edited by hayden
https://www.sau.com.au/forums/topic/222595-engine-temp-too-low/
The engine fans in the Nissans, in general, are quite efficient little beasts, and are quite capable of maintaining the engine temperature. Even on the hottest of days.
400k to a tank is pretty normal from most RB engines.
Should mention that it is a non-turbo
1 undo the temp gauge sender unit get a tester and put the end of it in boiling water and see if the resistance drops to near 0.
2 change the thermostat, could be jammed open or not working at all(broken)
3 the temp gauge sender is seperate to the ecu temp gauge sender so if one is faulty the the other still gives correct reading. also it usually the 2 pin ecu sender unit that gets shagged not the single pin earth type.(the heat contraction cracks the base of the plug over time)
4 most na skylines will get 12.5 litres per 100km's while turbo'd is 14.5 litres per 100km's (factory)
5 the viscous fan might be shagged and not slipping at higher then idle rpm cooling the radiator too much.
any one of these really.
Edited by nizmonut
Cheers, I'll have a look into these. :(
Definitely, as stated earlier, check the thermo as it may be buggered. It could be stuck open leaving the engine ...
If that were true, then this wouldn't happen:
If anything, it might be jammed shut, but then the engine would tend to overheat.
I strongly suspect that there is nothing wrong at all. But the temp sender can be tested in situ, simply by measuring its electrical resistance at cold and hot. (Don't have the specs readily available - will check tonight).
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
