Item: New/Sealed K&N Pod Filter
Condition: Brand new and sealed in plastic in box
Price: $90 including postage anywhere in Australia
To Fit: Any car, it is a universal filter with a 3-inch inlet and is 6-inches long
Contact: PM or [email protected]
Comments:
PART NUMBER IS KNRE-0930
IT IS A TAPERED DESIGN 6-INCHES LONG WITH A 3-INCH INLET/FLANGE
RE-0930 Product Specifications:
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 3 in (76 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 6 in (152 mm)
Top Outside Diameter: 4.625 in (117 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.27 oz (38 ml)
Flanges: 1
Inner Wire: No
Weight: 1.6 lb (0.7 kg)
Still for sale? or has ^ bought it already?
Still have one more for sale, let me know if you are interested.
tron345 you have PM.
Thanks
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
