Coilpacks on a 32 gtr are same as series 1 gtst yeah? Packs on my gtst break down at about 10psi. If i was to buy a set of coils off an r32 gtr that held 18psi would this solve my problem? Obviestly splitfires are a better option but just wondering if i can get outta it a bit cheaper for time being using GTR coils.
thanks guys
brett
https://www.sau.com.au/forums/topic/222667-coilpacks-q/
are your plugs gapped to .8? if not buy some new plugs allready gapped to .8 and fit them first
yeah thanks mate, already gapped to .7 and got new irridiums. definatly the packs breaking down. taped em up and it helped a bit but not huge amount
brett
https://www.sau.com.au/forums/topic/222667-coilpacks-q/#findComment-3924117
Yes, 32GTR and 33 Gtst S1 are the same coil packs.... think the splitfire # Is DIS-0001 or something.... around 400 ish these days for new ones, I wouldn't bother stuffing around with second hand ones. .. might find they have the same issues...
JJR ones are $399 a set but I have not had any experience with theirs.. most opt for the splitfires. Or genuine... think it works out around the same price if you have access to a trade card :)
https://www.sau.com.au/forums/topic/222667-coilpacks-q/#findComment-3927400
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
