Hey all,
Just made a trip out to the willobank test n tune, and had a few runs down the strip for my first time and it was awesome fun. Jus wondering if neone else has taken the Atmo Liners down the strip and what times u got.
My Best Run:
Reaction: .633
60ft: 2.326
KPH: 139.75
E.T. 15.815
How does this compare with the rest of you? is it ne good? i took the subs and spare tyre out for the night.
Cheers
John
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/
Congrats, good time
Just curious what speed were you pulling at 1/8 mile mark and what mods have you done to your car?
Haven't managed that yet in my car, I have a major problem with loss of traction, in 2nd I'll still get wheel spin, and even when launching at low revs.
My times were done at Meremere in NZ.
My best time to date is 16.0, mines a 4dr and I still had the tools and spare wheel in the boot.
My best speed in is 140.7KPH, and that particular run I did 16.4 (darn traction problems).
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-477962
cheers for the feedback
i had no spare tyre or jack and took my boot install out but i still had 2 big amps in there. If i can read my slip properly it says 660 ft i was doing 68mph or 110kph. The highest speed i reached was 87.17mph or 140.29kph and i got a 16.461 on the particular run and missed 3rd but got it back in after 2 attempts... oops... poor car.
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-478311
hey guys.
i have a vl n/a 5speed with a smallish cam.
the best time so far is 15.02 @ 148kph
this was done with two wheels, trolly jack, and a tool box in the boot. i didnt have a traction problem. lsd.
skyla.......i'm wondering how you have traction problems. wat size tires and diff do u have?
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-482420
I have 235x45x17 tyres all round and a LSD (4:3.1).
I'm think the problem is in the suspension, I need new shocks.
Before I changed the diff to the LSD, I was still running my old auto one (non LSD, 3:5.1) with 255x40x17 tyres, it was with this set up that I managed to get my 16 flat I got my 60ft time down to 2.389 which I felt happy about, the way it is now I don't seem to get traction:(
Any suggestions would be appreciated:)
Thanks
Rachael
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-482871
what dya mean by u missed 3rd NA_R33?
just wondering cause ive seen it in mags and etc abt ppl missing gears in drags and i was just wondering what it meant...
how do u guys get these times and etc?
do i just drive down to my local track here in perth and tell em i wanna do a 1/4 mile anytime im freE?
cheeres guys
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-489299
Um, pretty much yeah.
Quit motorplex has street racing meets on Sundays going again now, costs $30 from memory and gets you as many runs as you can fit in. I think they started again last week. web site is www.motorplex.com.au
Missing a gear normally means you didnt get the car in gear propperly, or went from 2nd to say, 5th gear. And its never a fun thing.
Do you all normally let tyre pressure down some for your 1/4s, if so, do you think it helps?
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-489363
thanks man...
so say if i were to feel bored on a wednesday at 2pm and had 30 bucks to spare, i could drive out to quit and give it a go...
and the next tuesday when im bored and yet again haf nth to do i can drive out pay 30 bucks and go again?
or is it only sundays?
thanks dude
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-489444
Generally you will find its only when 'they' specify. Your $30 for 5mins of use isn't going to cover the wages of 20 people that need to be there while you run.
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-489591
I drop the pressure a to 25psi, some people drop it as low as 20psi.
I find it does make a difference (better traction), my best times were done with 25psi in the rear tyres.
https://www.sau.com.au/forums/topic/22267-na-14-mile-times/#findComment-490309
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
