Hi all picked up my GTR V Spec the other week, love the car but after the initial excitment of owning this awesome machine I started to find out a few things that I am unsure about as this is my first GTR.
Is it common to have surface rust underneath the car, as mine has surface rust everywhere? Also some of the disk rotars are warped, I was told that it is not uncommon for this to occur as they run different brake pads in Japan?
How do you remove stock boost restrictor and do you need a boost controller after you do?
Will post pics soon
Any info greatly appreciated
Welcome,
It depends on where in Japland your car came from. If your car was from a place where it was close to the sea or snowed a lot then u would expect it to have more rust. Check you strut towers for rust, as i've seen a few Skylines and Stags with this problem. Did u import it yourself or did u get it locally? did u know the car had rust before you bought it?
Your boost restrictor is located on the boost solenoid which is located on the drivers side tower. you will see two hoses, one with a yellow band around it. pull the hose off the one with the band and squeeze the restrictor thru. u will get an instant boost increase a tad under 14psi.
Not sure where the car was from but purchsed directly from importer, have asked for import papers, should be in the post. As for rust I noticed a small amount on one of the seems in the drivers side shockie tower, not enough for concern as the car is very clean. Only noticed the surface rust when the car got serviced and was on the hoist.
nice, clean and unmolested.
any mods planned?
ps if you are lookin for new rotors, check under group buys, i think i remember seeing some DBA slotted ones.
Just after I picked up the car I bought a full Bee-R exhaust 3.5 inch into 4inch with Titanium muffler currently sitting in garage!
unfortunately I have taken the car back and have purchased another GTR which I will pickup next week.
At the time I picked up my 33 from the importer he showed me a sweet 32 gtr he had brought over. After going for a ride in it, the only thing I could think about was this 32 .
Convincing my wife the extra money was worth it was the hard part but after a while I got permission, so I picked up the phone and he kindly agreed to take mine back and I would pay the difference. Cant wait till next week!!! Have some pics of the 32 before it left Japland, only difference is the carbon fibre doors are gone and it now has r34 gtr rims.
Edited by Micko77
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
