hey guys
I filled up my car (R34 GTT) on sunday. i got like 300 kms for the tank. Should this be right? its stock standard other than just the Bov i put in a couple days ago. Should i get my injecters cleanded or something?
:P
Cheers!
could be your bov messing stuff up happend on my car made it run like shit aye use more fuel and go slower but im sure someone will say otherwise
:P
i still got 400+ with a atmo bov
really depends on what bov you have my mates got a hks super seqential and its was sweet as and i had a turbo smart and it screwed everything bad hey my car was almost undrivable...
put the stocker back on and see if there is a differnce if there is then you gotta think is that exstra $30 a week in petrol really worth it for that rice pshhhhh hahah
"I filled up my car (R34 GTT) on sunday. i got like 300 kms for the tank."
This is a very vague statement - how much fuel did you use to fill it up? When you have a litres per 100 km value then you can compare fuel consumption.
For example I get 10 litres per 100 km in my R33 GTS-T and I get between 15 and 20 litres per 100 km in my R33 GTR depending on how hard I am trying.
How much fuel did you actually use?
I get 300kms out of 50l of BP Ultimate myself .. just a turbo-back and boost at 10psi so far (was getting same economy on stock boost too) But the car is not tuned yet so I'm hoping once the ecu remap is done that economy will improve. I'd be more than happy with 400kms/50l
I thought the Skylines had a 60 or 65 litre tank????
I get 300 - 350/tank, and I have never let the needle go under 1/3rd, I usually put 30-ish leters in the tank. (so that's 30 litres for 350kms (remember I dont drive till empty).
EDITL: my super-leaned out Soarer was getting anything up to 900kms (estimate) from a tank on the highway, cruise control from Sydney to Brisbane and back with an 80 litre tank.
My PB was Filling up at Southport on the Gold Coast, and getting back into Chatswood Sydney with the 'less than 10' warning on the dash, and getting the 'under 5 litres' warning the next morning heading to a petrol station.
This was leaned off with the help of the SAFC II computer, got 846kms on that tank from a 1.86 tonne luxo barge.
B.
Edited by turbo_brian
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
