i have a T78 with rb30/26 in a BNR32
looking to make a custom 4" exhaust from turbo back.
question is..should i include a muffler or should i make it stright out.
disadvantage ?
and i guess i'll be using 321 SS stainless steel from burns
any thoughts or experience on that ?
should i also use heat wrap on this tubing ?
i see that on Burns Stainess's page, they have many selection of mufflers like
DR-1 Drag muffler
and
Ultra Light muffler
also using oval tubings. what's the effect of this ?
is it just for more ground clearence ?
https://www.sau.com.au/forums/topic/222686-custom-4-exhaust-help/
I would certainly be using a muffler and making sure it is straight through and at least maintains the exh id... that is assuming you dont mind the noise. If you do want to quieten it down, as an example a mate with a 4" has two rather large straight through magnaflow race series mufflers and that is imo very quiet at light throttle/cruise, as opposed to my 3.5" with a single 4" muffler which is deafening no matter what your doing.
btw that drag muffler is a merge collector design for aspirated drag motors (ie straight of headers)
Hey,
With that turbo and a 4" straight-through I'd guess you'd be at about 110-115dB. That's pretty loud.
You might want to have a listen to something that loud before you decide to do it; if you're
getting a full custom system done you'll save a lot of time and effort (and money) if you decide on
the configuration before you start :P They go harder with less muffling; but you can probably knock
10dB off that with minimal flow restriction, and another 8dB with only a little more restriction.
I'd probably try to get it down to about 95 using the best flow-vs-noise tradeoff mufflers you can find.
Below that mark on 4" I think you will notice the difference.
No experience with that vendor of stainless. I think you have to weld 321 with 347 so that may be a concern.
Heat wrap: no idea; I'd probably wrap the manifold but not worry about the exh. side. It's a _big_ pipe.
The oval tube is for more height clearance - you have more width + less height used, but similar area.
Hard to do 'the bends of your choice' with it though because it's indexed.
Round is easier, and you can fit a round 4" under a 32 with 100mm clearance everywhere
at SK's suspension GB ride height (minor relief needed when passing over the rear driveshaft area).
Regards,
Saliya
I use 304 for 2 reasons, 1 is cost, 2 is for availability of the material and bends, flanges.
I can often buy ALL the bends and straight right off the shelf!
Cracking is usually tracked back to thermal stress. Often where 2 pipes meet and they are running at different temps and/or lengths.
Like dump pipe and waste-gate join. Make sure you add a flexi-pipe! If in doubt, check out any decent GTR front pipes!
I wrapped my pipe until it had left the engine bay..
Help ya any?
Help ya any?
i thought flexy pipe was a good idea..but some say it's not important and it's only important on FWD cars.....but gtr has FWD too...
Help ya any?
your lucky.. i have to order all mine in majority of the time
3" - 300rwkw
3.5" - 350rwkw
4" - 400rwkw+
Thats a 'general' rule for exhaust size.
Yeah a 3" will 'flow' 350rwkw, but put a 3.5" on there and you'll see the benefits right away.
You can easily get two mufflers, plenty of places sell 4" ones these days, plentiful on the market.
Will still flow brilliantly and have a nice note, without being a massive noise/drone box
I would be trying to thinner in wall thickness then 1.6wt. Way too heavy for an exhaust, maybe the dump pipe and front pipe will be fine in 1.6mm, but after the cat you can drop it back to 1.2mm
thinnest my supplier has is 1.6 in 4inch and 3.5.. can do 3inch in 1.2 tho if your that concerned about weight.. you can go titanium.. but that will cost an arm and a leg...
3" - 300rwkw
3.5" - 350rwkw
4" - 400rwkw+
Seen enough ~400RWKW cars, with ZERO gain from a 3" to 4" exhaust...
Of course a car with no mufflers, ext gates not plumbed etc etc will do it.
Road cars, with a level of noise legality surrounding noise, ride height and so on, simply not going to happen
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
