hey guys, my r33 has got some problems i need to fix asap, firstly, sometimes when i start it, it seems as if there is a boost leak or sumthing, it doesnt stay on, just turns on and off??so i drive it revving abit?...then sometimes it just gets better and runs normal??..ill check that up 2morrow tho...2ndly, the car makes heaps of popping noise (backfires) when you let go of the accelerator and slow down, it pops like 15 times (pop, pop, pop,.....15 times)...it's real loud and scares people next to me, (i hope i dont get a cop next to me!!)...also finally, the car feels like its lacking boost slightly when taking off in first gear (really little, not that much of a problem but thought id state it anyways) and gets better in 2nd and so on...so guys??...sorry for being so messy, its coz im in a hurry trying to find out the problems..
also, im really sorry if any of these things have been spoken about before, im just in a hurry to fix these things
cheers guys
abdul
https://www.sau.com.au/forums/topic/222700-r33-gts25t-problemsplease-help/
i'd be checking for boost leaks... that would cause backfiring as it'll be running rich,
is the car revving up and sown on idle then stalling out???
If so look up the TUTE on cleaning the AAC valve and adjusting idle... should fix it...
hey, how wud u suggest i check the boost leaks??
go around and nip up all your hose clamps, see if you can hear anything... check all your lines coming off your plenum, make sure they are still attached...
If it's a big enough leak you might be able to feel it... also check your BOV... disconnect the rubber plumb back hose and put your hand over the outlet of the BOV as it is building PSI...
  • 3 weeks later...
i still have'nt fixed this problem yet, when the car runs low on the fuel, the backfiring (popping) seems to slightly get better (it only pops on gear change), and also the stalling problem gets better. when i refill it with fuel (BP Ultimate and 98 Vortex), until the fuel gets low, i gotta deal with loud popping and stalling problems :) i tried the TUTE on cleaning the aac, it helped, but no so much.
any help would be greatly appreciated
cheers
AFM problem would be idling below 500rpm but the engine won't die. That what happened to me. My mechanic used some AFM spray , i don't know what it was and it was ok. Now idling is around 800rpm (from stock odometer) which is back to stock. No problems since.
contact cleaner to clean the hotwire
try it - also try disconnecting the AFM - if the rev dont change it might suggest the contact points within the AFM are broken/not 100% - you could test another persons AFM if available
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
