Hmmmm... Im not convinced.
You can easily crowd it to much, all that the banner is for is to attract the eye of anyone who is wandering around at a show looking at cars, to show who we are and what club we're a part of... It doesnt have to incorporate every single Skyline ever made.
I think we should put this to a vote.
  • Replies 123
Posted Images
I'm with Mick on this one too. Don't know about the R35... its technically not a Skyline from what I have been led to understand and we are Skylines Australia.
I like the one pictured, it does have a good visual effect and if you wanted to do a standing banner (like I mentioned a few posts ago) it might be a good one to put the rear ends of the different models in a vertical banner. Then we can have both at our presentations.
Wotcha think?
yeah i was happy with it (from memory :P ) although I would make the Skylines Australia text a bit bigger.
The pic should work if you link it, rather than uploading to here. Do you have a photobucket account or something Mick you could link it from?
How are we going with the money for the bigger banner? May know of a way to get together some money through Sponsorship, if you guys would be interested in that. How much are we short at the moment for a larger banner? If it is not much i can always contribute some.
I don't think we're far off now - I think John has the final quote, but we'll keep fundraising for a vertical banner at a later date.
I noticed they are doing banners for a pretty good price on ebay, might be worth querying on quality, although it won't get that much wear and tear.
yeah i was happy with it (from memory :D ) although I would make the Skylines Australia text a bit bigger.
Nope...
Just tell admin to sort the new server issues out :)
We have enough money, the thread says so. Even for the larger 3*1 meter banner.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
