Yep, couldn't agree more.
Both would look nice, but definitely the bronze XD9s on a midnight purple car.
+1 :D
I've got 18" x 10" +18 (Bought from JDM Concept - The ONLY authorised Work distributor in Australia)
+18 is the PERFECT offset for you 33. It will sit just under your lip.
Edited by im late
just double checking.... +20 or +18 18x10 will fit under the R33 GTR gaurds without lipping or rolling them? And wont scrub?
Only a 2mm difference which is nearly nothing so definitely the +18s. If it just rubs because of the 2mm then dial in some neg camber to clear it. It doesn't take much. But if you bought the +20mm offset wheels and it was a little too weak of a fitment (if that's what you're after) you'll have to add spacers which is illegal and you might not want to do that.
+18.
Edit: I just pressed post reply even though I hadn't even finished what I was going to say. :D
Edited by adam-__-
