hi guys was just wondering if anybody knows if RSFour suspension is different to the suspension i would have in my RWD RSV. there are alot of coilover kits for RSFours but not a big range for the RWD stagea and i just wanted to know if there is a difference.
https://www.sau.com.au/forums/topic/222760-suspension-difference/
hay champ i have a 2001 rsv the rear coilovers are the same But the front is totaly different :cheers: im an still looking to find coilovers that will fit fit in the front
the brakes are different then rs4 too what year model is urs.
i have a 98 model series 2. do you know what the difference is in the front or do you just know its different. the RSFour has a GTR front suspension set up so im guessing that maybe an RSV is more similar to a 33GTST. i really dont know enough about either of the models to say to much but i have found a few sets of WGC34 (not WGNC34) specific coilovers on a few sites. just wondering also if SK will be able to differentiate the difference between the models as im going to be ordering some sway bars from him as my car doesnt even have a rear sway bar fitted.
There is some talk about RWD brakes in the Stagea Brake thread atm but don't think any of its conclusive yet. And afaik the RWD's use a fork setup like the GTR or 260RS in the back instead of the bush GTST type. And I think that the strut top hats or something need to be machined down a bit to fit as well, once again afaik. Try the yahoo auctions through import monster or slide and see if they have anything listed for RWD stageas. Might find something :)
also what difference have u noticed with the brakes. i was thinking of putting 33 gtst calipers and discs in soon anyway so it probably wont matter that much.
Gtst caliper will fit, but a couple of washers are needed to space the caliper correctly. Gtst rotors will not fit at all: the offset is completely wrong (around 5mm or so).
well thas funny cause i just went out and had a look at my rear shockers and i definatly have bush type not fork struts. about the brakes i would just like to know why they would have diffent types just for a RWD and AWD. bloody stageas this is getting to be annoying.
i just got these of import monsterpost-44842-1212979188_thumb.jpgpost-44842-1212979205_thumb.jpg $200 + postage for RWD specific coilovers with the standard springrates and camber tops
these look to be the same as mine but mine are na in the rear they will fit let me know how u go putting them in cos i want a set of adj rears
Yeah that was my bad, I was getting confused with the series 2 rs4s manual stageas not the rwd stageas.....oops :thumbsup:
The 4wd Stageas have a shorter front shock and spring as they have to leave room for the front driveshafts. This requirement also affects the front swaybar location and the front radius rods. The rear is the same for the 2wd and 4wd, only the 260RS is different as it has GTR style forks for the lower shock mounts.
You can use R33GTST front shocks and springs in 2wd Stagea, but the rates aren't ideal. Much the same as using R33GTST rear shocks, they fit, but aren't designed for the extra weight and higher CoG of the waggon. You still can't use R33GTST rear springs as the Stagea top mount is much narrower, presumably to increase the rear load space.
Cheers
Gary
RWD S2 stag uses mac strut type front suspension so R33 will not fit.
I would say rears probably wont fit either.
C34 Laurel shocks are the best fit and are what i have, along with RWD stagea specific Tein springs.
Its the same style as s14 silvia but it think the silvia is shorter?
You will find that parts for a rwd stagea are a PITA.
Dmonic. Those green coilovers in the pic look correct, i would go for those.
Edited by GorGasm
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
