ive been trying to take off my front bar for an hour now and i cant for the life of me find the last 2 bolts holding it on it seems to be underneath the headlights somewhere it feels like im going to snap if i pull any harder
can anyone help me out here im pulling my hair out
https://www.sau.com.au/forums/topic/222763-please-help-urgently/
rememeber there are two big plastic clips kinda like big fat bull clip thingys below where the headlights meet the grill...somehwere around that area. If you have taken all the bolts off then these will be the only things holding it. you can slide something thin say 2mm or so inbetween to lever and pull out the bar but make sure you dont lever too hard as it will snap. just enough to pull the bar out.
3 plastic plugs under the grill, one under each indicator, one screw at each side (top of the arch)
3 on the under side of the front bar (directly below the 3 that where under the grill)
to pull the indiacators you'll need a phillips screw driver, pop the hood and where the headlight meets the gaurd you'll
a small plastic tap moulded from the housing of each indicator lense. undo those and pull the indicators directly forward.
