Item: 1991 Twin Turbo Soarer x 2
Website: Your on it
Item Condition: Good
Reason for Selling: Finished project.... next please
Price and Payment Conditions: $12500 for both cars or swap the black soarer alone but i have to sell the green one dont mind swap for both cars with $2500 with cash adjust no less though as the green car belongs partly to my best friend and i must pay him out if going to sell cheers all.
Black soarer - $10000ono
Green Soarer - $4000ono
Black Soarer: Ok so i got this got this car a while ago as a unfinshed project from another boost member and have basically put the finishing touches to it. I have had the car repainted and the Bn kit properly fitted and painted. Also had all the power steering lines replaced and full service carried out. All the usual soarer problem electrics have been fixed also. Please note all work has been carried out by professional reputable workshops around the Gold coast area and i can provide receipts for work carried out.
Now the car is stock mechanically save for a Turbosmart Type 2 Bov and Turbosmart Dual Stage boost controller. Please note car has 140,000km's on the clock. The car also features a Full BN body kit, 18x8 chromes with Bridgestone Potenzas all round, Clarion usb headunit with remote, a kenwood 4 channel amp, Matched front and rear pioneer speakers and a kenwood 1500w sub in a box, Sun-roof, Missle switch on board for 2nd Stage boost, Neons in boot, Leather dash and doors no cracks or damage, Boost Gauge and new carpets. Car has rego till Oct. If i have missed anything i will update alternativly if you have any questions please dont hesitate to ask me cheers all.
Green Soarer - More of a complete parts or drift car, its complied and can be registred. It in ok nick panels are straight paint has some flaws. Roughly 200,000 on clock i think its in storage will check soon. Interior is okish its all there though just stains really. Motor starts and runs car cant be driven due to flat tire. In short i wouldnt say buy it and drive away with no problems rather it does run but needs work, or just use it as a parts or drift car which was what i was going to do. Strip it out manualise it nice cheap 1jz drift car.
Pictures: are <---- there
Contact Details: Post, Pm or 0415 560 620 ill get back to you asap
https://www.sau.com.au/forums/topic/222766-2-x-twin-turbo-soarers/
Hey bro how you been. Neat lookin ride there. Should be drivin the line again this week so should catch up. You could always flick me quite a few g's and i may swap:P
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
