  • Replies 41
i wouldnt mind getting into that too. i have a nitro powered car which i got from the hobby man in dandenong. was 600 for it and i guess the drift ones would be a lil more. im gonna look into it too and will post how much it is on wednesday.
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3926168
I dunno, but maybe try some of the hobby places in the CBD first. There's one under the Myer overpass on the Melb Central side, and I think another one on Swanston quite near to Flinders Station, opposite the cathedral. They definitely sell RC stuff and Japanese car stuff, so that might be your best bet locally.
If not, you can always try eBay as said.
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3926550
They are not that fun, I got over mine quite fast.
I had a TT01 which I built like 4 years ago when RC drifting was unheard of here in australia - it had a HPI S15 shell on it, 23T motor all all the drift goodies - swapped it to a member on here called FERNI (purple 33 GTR) for a desktop computer. It was alrite - but you do get bored of it.
I have a Nitro powered Kyosho Inferno buggy - and that thing is 10 times more fun than any drifter - it actually drifts better and more realistically on big streets with shitloads more speed than any electric ive seen! Plus sounds good too!
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3927147
what do you guys want to know about them?
as some people may know i use to run RCD1 a full rc drift championships in melb and did all the autosalon events and driftfest and so on
still in contact with my sponsors and so on :D my rc car cost around 1500 in total and was full carbon fiber and hit a top speed of 110kph :thumbsup: and bat life was 2hours :D
so yeah tell me what you are after like budget? and i will help you out as best as i can
there is a small movie of some of the guys
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3930152
still in contact with my sponsors and so on :) my rc car cost around 1500 in total and was full carbon fiber and hit a top speed of 110kph :) and bat life was 2hours :)
Holy shit! 110 kph from an RC! That car can be snapped for speeding even on the freeway lol. You could be driving and your passenger could be racing you with the RC.
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3930784
yes there is a shop in hoppers crossing there a bit pricy but non the less a shop some footage from there indoor track is on the vid
as for the RC car yeah 110kph was clocked on a bike velidrome* SP? with foam tyres and the motor Tuned for max power GO MAMBA laptop tunning :P
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3931157
I got two from eBay - best purchase ever! The stores i checked out first were way too expensive, i picked up my two for $100 each brand new. The biggest spend was buying drift wheels, a second shell and extra batteries for longer play, (about another $100 all up) but i've never regretted getting them. My artist mate did one up with paint and stickers to resemble his car exactly (S15) and mines the same as my R33 so regularily when we go out cruising we take these bad boys with us!
another friend i know has a nitro powered car but it spends more time in his garage fixing the damn thing than out with us as its so powerful everytime he drives it he smashes it and you can't drift so its not as much fun i think
my suggestion - definately go eBay!!!
(or if you want to see the ones i picked up off ebay meet us some time when we go cruising with them which is usually every week or two in the south east Waverley area. pm me if you want)
https://www.sau.com.au/forums/topic/222788-rc-drift-cars/#findComment-3931440
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
