Make: Nissan
Model: R33GTR V-spec
Milage: 93,000kils
Transmission: 5 speed Manual
Colour: maroon
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: 29,000 (price negotiationable)
Contact: [email protected] or call me: 0401252118
Comments / Modifications: 2.6 l twin turbo rb26dett engine just reconditioned within 20000 kils
Two brand new r34 gtr N1 TURBO fit around 1 year.
New OS giken twin paltes clutch just fit with in January 2008.
Nismo short shift
Hks EVC boost controller
Hks high power exhaust ( got original gtr exhaust in my home)
Tein super street suspension (Australia edition: also have original suspension in home)
Nismo camber kits
R34 gtr wheels with nearly new falcon 265/35/r18 tires
Momo steering wheel
Apexi power FC ECU with hand controller.( standard computer available)
Twin Hks blow off value (original blow off value in my home)
Hks oil pressure and boost meters.
Sony cd player
Air condition
Abs break
All new general brembo break pads just fixed in the beginning of the year
ARC metal air box and oil catch tank
HKS full kits intercooler system
Turbo timer.
New 4wd pump
new air flow meter
no accident. Always garaged and well serviced (every 3000-5000 kils using gold mobel f1 engine oil)
I have this car for four years, everybody knows if you purchased a import, you will spend a lot of money to fix the car first, then upgrade. during the time, I also not only upgrade the car but also repair the car. I can say the car is not the most powerful car in the country, but it is one of GTR which have the top conditions in the country. you will save the money if make the deal.
the car must sell, because I will leave Australia soon, this is a big chance to have a top condition GTR, I am the only owner since the car import from Japan in 2004, cost 40,000 dollars at that time, and I spend more than 25,000 dollars to keep and upgrade the car since I got her. The engine reconditioned recently and I put two brand new N1 turbo with the car, so, don't warry the engine and turbos, they are still new! I am really love the car, as you see, I will leave the country, I have to sell my lover. Just want to find a good buyer to keep her.
Images:the images in the attachments
Edited by red981
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
