hey guys i got a r33 i have a problem wen the revs get to 4 grand the boost jumps up to 13-14 psi and cuts out and plays up until redline, up until 4 grand it runs 6-7 psi no problems, i did have a bleed type boost controller on there i thought that may be the problem but its not, i have recently put a front mount, pod,splitfire coil packs, new fuel filter and new plugs nothing has fixed. i tried the search option but nothing has cum with my similar problems.
https://www.sau.com.au/forums/topic/222880-boost-problem/
mate it wont run 10psi it will run 6-7psi upto 4 grand then jump up to 14 psi after that, itook my boost controler out i thought it may have been that and now iam running standard boost controler, but it just wont hold boost after 4 grand
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-3928752
what boost does it run if you hook a pipe straight from the intercooler pipe to the actuator (don't use the pipe with the restrictor in it) if it holds boost ok then your stock boost solenoid is hooked up wrong, if it doesn't you actuator is probably stuffed.
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-3928893
  • 3 months later...
well changed the actuator no luck, put a 3 inch dump pipe on aswell earlier in the week made heaps of difference until the boost problem any ideas please its really starting to p**s me off, or would it b best to buy a different turbo, if i go that way i would to geta highflowed item.
Edited by bwebbie1
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4145151
hi,
just curious ... did you gut your cat? are you running a standard cat or hi flo? as I have the same problem which started after I gutted mine and installed a JJR split dump/front pipe.
regards Rob
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4145198
I am going to put a cat back on the system and see if that sorts it out... I think the exhaust runs too freely now and the gasses from the wastegate dont get to merge with the main pipe effectively which causes the over boosting... x fingers .. have already dropped the split dump pipe and ground out the wastegate side so waste gate opens freely so isnt that... will let you know how i get along.
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4145411
Read thru this thread, might help.
http://www.skylinesaustralia.com/forums/Bo...26#entry4144426
If you’re running a jjr/ebay split dump/front pipe then you will have boost spike issues.
At 13-14+ psi the stock ecu will R&R anyway so it will feel like it dies after 4500rpm, you may even hit boost/fuel cut at that stage. Bleed type boost controllers have a very common problem of boost spikes, if you want steady boost I’d look for a gready EBC, apexi ect for steady boost levels.
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4145807
hey guys this is problem a dumb question but wen we installed the front mount the problems started so we were thinkn that we might have the intercooler around the wrong way??? is this possible that the flow is not wroght or doesnt it matter??? cheers thanks
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4161200
It doesnt matter what way the intercooler pipe is.. try a good boost controller, an electric one... not apexi either a blitz, hks or greddy
could be the dump pipe but it sounds like youve had 2 dumps pipes on and the boost played up with booth?? was the first one stock?
can you chek to see if the actuator can open fully with the dump pipe on?
https://www.sau.com.au/forums/topic/222880-boost-problem/#findComment-4161246
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
