Hey Guys,
I'm trying to surprise a friend with her favourite chocolate, but she wont tell me where to get it from...
They're Peanut Butter Cups, but I dont know the brand name, and they are VERY rare. Brought in from America, and only sold at a few places.
Does anyone know where to get it from?
They look like M&Ms apparently, and have peanut butter in them with chocolate.
HELP ME OUT HERE!!
Rhys
https://www.sau.com.au/forums/topic/222911-peanut-butter-cups/
dude they're not that rare, i've seen them in IGA and other special candy stores like 'sugarfix'.
Funny how you say its not that hard to find but your not even from WA, how do you know its easy to find over here? We dont even have a sugafix store!!!
Anyway i would try the lollishops in markets as they usually have "world lollies"
Reeces Peanut Butter Cups.
There is a shop in London Court that sells mainly english chocolates but also sell the peanut buttercups.
There is also another shop that sells them in Carrillion Arcade near EB Games and Dirtcheap CD's. This one has a bigger selection.
Grab some peanut butter m&m's while you're there, they're teh b0mb!
Edited by bubba
Theres a lollie shop in mandurah that has heaps of stuff. . im guessing it would be too far away though. .
One of the big kit kat fingers has peanut butter in it too. . and another with cookie dough :D yum haha
yeh i know but still im not a fan of reeces or any american choclate aye,
i worked in the us for 6months last year and my mum frequently sent me cadburys, the yanks loved it
Yeah even my mates' wife reckons our chocolate is better than in the US. English Cadbury's is better again as they don't need the heat preservative that we put in our chocolate here.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
