u can also get them highflowed to add some extra power, although the costs may not be worth it
or pick up some cheap top feed GTR injectors from a GTR owner looking for big HP and get a top feed rail made up so it can fit a gts-t
GTR low impedance injectors, GTS high impedance injectors.
By the time you have finished rooting around getting fuel rail, resistor packs then trying to fit them (wouldnt be easy with a stock plenum) - you would have probably been cheaper to just get larger side feed injectors.
High flowing injectors is pretty bodgey, can be disasterous.
Like BOOSTD said, fuel pressure reg (under $200AUD) and you can stretch the stock ones out to 250+rwkw.
Otherwise do it right and buy some larger injectors.
