Do it yourself :) Its pretty easy
Have you got all the tiles and grout?
Just put the grout at the bottom of the tiles and use matches to space them. Then fill the gaps with grout and wipe the excess off with a wet rag when its starting to dry :)
If you really get stuck I can give you a hand. I have a tile cutter too if you need. My work shifts are pretty ghey though, so it all depends on that.
Edited by NISZILA
hey coz when do u need one by?
there is one guy workin on ma bro in laws house atm he should be nearly done might be able to get his number for u if u wanna give him a buzz
msg me if u wanwt details:) n he's wokrin on their house which is in southlakes atm so i'm taking it as he is south of river too
  NISZILA said:
Do it yourself :( Its pretty easy
Just put the grout at the bottom of the tiles and use matches to space them. Then fill the gaps with grout and wipe the excess off with a wet rag when its starting to dry :cheers:
I have everything and it's all prepped and ready to tile, but I didn't feel confidant about doing the walls :S So I really need a tiler.
Thanks everyone for the quick replies! :)
quote Do it yourself :) Its pretty easy
Just put the grout at the bottom of the tiles and use matches to space them. Then fill the gaps with grout and wipe the excess off with a wet rag when its starting to dry :P
If you really get stuck I can give you a hand. I have a tile cutter too if you need. My work shifts are pretty ghey though, so it all depends on that. quote
hhaha what the f**k if you do it that way your gonna have big trouble :D
and it sounds soo easy to do till you try it cause it can be very messy
i am a 4th yr floor and wall tiller and know how in demand tiller are .put an add in the paper and just say you want a tiler for small job ..most ppl will be willing to do it cash cause it is cheaper for all.
