Are There Any Other Girls Who Drive Skylines On The Forums On Here?
  • Replies 63
This thread really needs to be locked..
its turned into pointless off topic bullshit..
might aswell call it the second wasteland..
Ah haha!!
You started it.
If you do a search in the Member section and filter out the search just to be Female, you will find there is about 13 and a half pages multipiled by 20 per page, which equates to approx 265 / 270 Girls on SAU. (Members set their gender to Female that is)
Again, it will be good to see a lot more girls inputting into topics and threads.
and I can tell you that there are 22 female members of SAU VIC, but a couple don't drive 'lines....... need more chickz0rs in the club!! :nyaanyaa:
I'll join! Just because I want to whore your members threads. And I hate that I don't have access to your execs threads anymore!
lol @ how thread keeps going off-topic
the only females that answered the question arent even in vic :whistling:
It's because NSW FTW!
See what happens when you post stuff like this... It's like starting up a HI OMG ASL dating thread.
There are a lot of girls on SAU but none of you are as cool as Liz and I! bwahaha!
Guest
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
