the best place is next to the compressor outlet
that way you take out any loss from the pipework, intercooler core and other junk along the way
if you look at pics of the HKS 2835 ProS youll see the actuator gets a signal from its own compressor cover, this is the ideal way
but most common places are intercooler pipe work before the intercooler is fine
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3928896
this is 100% right unless you have a turbo with a large compressor wheel and very small housing. an example would be a bax oversize rb20 turbo. there is to much turbulance and pulsing to get a steady pressure.
in this case you are best off getting your feed 10 to 20 cm away from the compressor housing. I have found the profcb and other solenoid ebc's do not cope well with turbulant boost scources. this is due to the sample rate they use and their limited processing ability.
cheers :thumbsup:
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3929689
CEF11E and Paulr33..... i don't mean to take nything away for you guys as ur right in your application
BUT i believe airbornesoldier is talking about a line for a BOOST GAUGE...the usual place for a mechanical gauge is to just tee into the stock like which comes out from the back of the plenum (my old r32 did anyway).
unless im missin something here i think u guys are talking about the boost line from turbo to actuator to control wastegate...this is entirely different to boost pressure reading line for gauge and i thought i've read here that that actuator line should never be used as a boost reading.
a) because it'll add a bit of overboost
b) if somethin goes wrong at gauge side of things you've very possibly got infinate boost!
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931315
This is the way i plumbed it on my r33. Teed it off the vacum hose coming out of the plenum (where the stock boost guage gets its reading i believe). Stock Guage and Aftermarket digital guage both work nicely.
I think the main thing is to make sure its after the FMIC, otherwise your reading the boost the turbo is making rather than the boost at the engine.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931504
i d go along with what WAN73D & Housie are saying. I also T'd off a nipple at the back half of the plenum (R32 RB25DE+t).
I think I'll put individual nipples for BOV, boost gauge, wastegate actuator feeds, now I have the plenum out for fwd facing plenum mod - it was getting too messy with T off another T etc.
At the same time I'm putting a spare boost gauge at the compressor housing, just to be sure of what boost the turbo is making before all the pipework - I hear 25DET turbo is good for 12 psi ish at turbo and wanna make sure it's below that at turbo.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931656
  • 1 year later...
I just got my boost signal right of the stock line, pulled that one out and put it straight to my boost gauge, its at the end of the plenum. And my boost controller signal is connected to my fuel regulator line.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-4992780
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
